March 27, 201610 yr I have for sale 20 Tube Evacuated Collectors (Qty 5), 230 Vac Circulation Pumps (Qty 20) and Controllers (Qty 20) at the following pricing: HiTemp Evacuated Collectors: R3000 - Sold Out HiTemp AC Pumps: R500 - Sold Out HiTemp SP 24 Controllers: R600 - Sold Out Pictures to follow shortly.
March 27, 201610 yr I'd be keen, just need to find out what it would cost to get to JHB. Have you got specs on the collectors and controller?
March 27, 201610 yr Author No specs yet on the collector but here are some pics and details: 1) The collector and frame is aluminium, bolts are stainless steel. 2) Heat pipe vacuum tube, dimension 1.8 M long by 58 mm diameter. 3) Brass reducers 4) Shipping Details: Header 2m by 200 mm by 200 mm, 15 Kg; Tubes 2m by 350 mm by 160mm, 30 Kg (Qty 2 as 10 tubes/box)
March 27, 201610 yr Author The SP24 controller details are as follows: 1) Control unit with remote LCD Display. (3 Temperature Inputs, 2 Pump Outputs and 1 Auxiliary Heating Output) 2) 1 PT 1000 Sensor for collector temperature measurement. (Silicon cable can handle up to 280oC) 3) 2 NTC 10K Sensors for tank temperature measurements. (PVC cable can handle up to 105oC) 4) Three time periods for auxiliary heating. 5) Controller includes frost protection, holiday function and overheating of storage protection. 6) Shipping Details: 340 mm by 240 mm by 60 mm; 1.3 Kg
March 27, 201610 yr Author AC pump type 15-6 specs: 1) cast iron construction. 2) 230 Volts, 50Hz, 3µF cap, IP 44. 3) max temp = 110oC, max pressure = 10 Bar. 4) 3 speed settings with associated power consumption of 46, 67 & 93 Watts 5) Shipping Details: 150 mm by 150 mm by 150 mm, 2.5 Kg .
March 27, 201610 yr Hi Carl plz help with dimensions of packaging and weight so I can find out shipping costs
April 14, 201610 yr Hi Carl 1. Do you still have the collector and tubes available? 2. Is the price genuinely R3000 with the tubes, or did I miss something? If that is valid, then I will take 3 (addendum to my own + 2 friends)... Please confirm, because it isn't clear in the advert. Regards KLEVA
April 14, 201610 yr Author Hi Kleva, unfortunately all the collectors are provisionally sold. Regards Carl
