October 9, 20205 yr Hi Powerforumn community, I have recently bought 2 pylontech us3000 batteries, I see that when they were installed, the installer connected the comms cable to link port 0 on both of the batteries. When i read the manual and on the forumn, it appears the people connect link port1 to link port 0. Does it make a difference? Thank you
October 9, 20205 yr Author Thank you PhilFM, do you perhaps know why it must be connected in this way?
October 9, 20205 yr 1 hour ago, Cuzz said: When i read the manual and on the forumn, it appears the people connect link port1 to link port 0. Pic of PhilFM is the correct way it should be connected. Pylontech say it should be connected that way. If you add another battery later,the new battery becomes the master and goes on top.
October 9, 20205 yr Author Thank you Quwatush Shams (Suly), do I need to power down the battery first or can I do it while the battery is running.
October 10, 20205 yr Author Morning, so I switched the cables as per recommendation, that is port link 1 to port link 0 with batteries switched off. After about 5 minutes of running, the master battery appears fine, on the slave battery the run light and Soc lights are all on for about 3 seconds and then all off for about 3 seconds. Is this normal. The red alarm light is not on at any stage, on either of the batteries. Also whilst like this with the cables switched, the Soc on my inverter(sunsynk 8.8kw) shows 94% whereas before I switched the cables it stayed on 88%. So my question is: in current state where run light and Soc lights flash on and off, is this OK or normal?
October 10, 20205 yr Author Thank you Vassen much appreciated. I will monitor the system and see how things go.
October 10, 20205 yr With regards to the unti staying on 88%, this is normal for the Pylontechs or atleast mine does the same. It would stay on 88%/ 89% for quite a while and then all of a sudden jump up to 97%.
October 10, 20205 yr Author 2 hours ago, Bloubul7 said: With regards to the unti staying on 88%, this is normal for the Pylontechs or atleast mine does the same. It would stay on 88%/ 89% for quite a while and then all of a sudden jump up to 97%. Thanks Bloubul7, I see that since I changed the cables for the link port the charge % is starting to go up again. Now at 97%.
October 12, 20205 yr Author 22 minutes ago, PhilFM said: Cuzz, what inverter are you running? sunsynk 8.8kw
