Solar Install for parents please Help.
On 7/14/2016 at 11:02 PM, The Terrible Triplett said:
Lekker man!!!
6 x 200W mono panels connect them:
Series: 3 x panels = 106.5 volts Open circuit, Axpert is 145v so your are good.
Then parallel: 2 strings.
So you have 14.04amps @ 106.5volts = 1495.26watt array.
4 x 12v 205AH US battery = 24v = 410ah bank
At 10% charge rate you need +-41amps - Axpert can go UP to 60amps on solar.
Sure some of the other guys will add more wisdom here to ensure you are on the right track, that I got it right, but all seems to be spot on! ;)
Well done!
EDIT: I like the 2w standby and 98% efficiency of the MPPT. 90-93% of the inverter, not bad at all.
And the 10ms transfer times, I like.
Hi Again,
So Systems has not been fully installed, in my absence a lot has happened.
So it turns out the Panels that were installed were infact 150W panels as against the 200W earlier discussed so we currently get about 60-66 VOC. I am not haoppy about this obviously and I have been offered 2 Options, 1.
1. Supplier to extra panels to match the 6 already installed to make it 4 strings each specs more like what below
Or Option 2
Take back the panels and refund.. (Ideally preferred but way too much hassle)
If taking the extra 2 Panels will be fine, I dont mind really as I can put this down as part of the learning Curve.
Any advise will be much appreciated.
  • Replies 79
  • Views 18.8k
  • Official way, for now, is to buy the ccgx for monitoring. That's another 350 Euro. I tend to agree that if I was on the right side of the exchange rate, I'd go Victron, but I have to temper my fanboyn
  • SilverNodashi
    SilverNodashi
    More batteries doesn't necessarily mean more problems. If you're looking at using flooded batteries, you'll either use 2V or 6V cells in any case. I have 16x 6V batteries in my bank, on 48V system
  • SilverNodashi
    SilverNodashi
    Agreed. And add what you use during the day to your PV system. We use more power during the day than at night, often 4x more. So our PV system is 2.5x what the battery bank can hold, works out fine at
More panels is more wires and frames BUT as long as the volts are in line, the power is there as you expected, it is ok versus frustrations to get it all started again.
12 minutes ago, plonkster said:
Sell them to me at a good price :-) My array is made of 150W panels.
You opportunist you, pulling such a blatant TTT move! :D
EDIT: If it was 310+ panels ...
