June 16, 201610 yr Is anyone also getting this error on an intermittent basis on the forums...? Been happening for the last 3-4 days ... An error occurred (500 Error) We're sorry, but a temporary technical error has occurred which means we cannot display this site right now. You can try again by clicking the button below, or try again later. Fatal error: Uncaught exception 'ErrorException' with message 'mysqli::prepare(): Couldn't fetch IPS\Db' in /home/powerfo/public_html/system/Db/Db.php:385 Stack trace: #0 [internal function]: IPS\IPS::errorHandler(2, 'mysqli::prepare...', '/home/powerfo/p...', 385, Array) #1 /home/powerfo/public_html/system/Db/Db.php(385): mysqli->prepare('/*IPS\\_Task::qu...') #2 /home/powerfo/public_html/system/Db/Select.php(346): IPS\_Db->preparedQuery('SELECT * FROM `...', Array) #3 /home/powerfo/public_html/system/Db/Select.php(402): IPS\Db\_Select->runQuery() #4 /home/powerfo/public_html/system/Task/Task.php(110): IPS\Db\_Select->rewind() #5 /home/powerfo/public_html/system/Dispatcher/Standard.php(295): IPS\_Task::queued() #6 [internal function]: IPS\Dispatcher\_Standard->__destruct() #7 {main} thrown in /home/powerfo/public_html/system/Db/Db.php on line 385Fatal error: Uncaught exception 'ErrorException' with message 'mysqli::prepare(): Couldn't fetch IPS\Db' in /home/powerfo/public_html/system/Db/Db.php:385 Stack trace: #0 [internal function]: IPS\IPS::errorHandler(2, 'mysqli::prepare...', '/home/powerfo/p...', 385, Array) #1 /home/powerfo/public_html/system/Db/Db.php(385): mysqli->prepare('/*IPS\\Session\\_...') #2 /home/powerfo/public_html/system/Db/Db.php(688): IPS\_Db->preparedQuery('REPLACE INTO `c...', Array) #3 /home/powerfo/public_html/system/Session/Front.php(300): IPS\_Db->replace('core_sessions', Array, true) #4 [internal function]: IPS\Session\_Front->write('f251a5ab7952a17...', '') #5 {main} thrown in /home/powerfo/public_html/system/Db/Db.php on line 385
June 17, 201610 yr CTRL + F5 Hi Guys & Ladies Deep apologies for the down time. Our currency application upset the database of your forum, Unfortunately we had to remove currencies. But we will have some more Karma Points systems up my sleeve. If anyone has a problem please refreshed the cache of your browser by pressing CTRL and F5 keys at the same time, and if persists, let me know asap at power(AT)powerforum.co.za Thanks for the patience. We running at full steam again. Thanks all. May the Forum be with you. Sincerely Jason
June 18, 201610 yr I used to be a PHP/MySQL dev, ten years ago. When my mother asked what I do for a living, I told her I play the piano in the local whorehouse. :-)
June 18, 201610 yr Jason traced the error to TTT wanting to spend his 200 units on a firepool. The ensuing outcry (not) caused the server to crash.
June 18, 201610 yr Hahahahah! Will introduce Karma points that will hold a value to the store. Fire pool. Heheh!
