Raspberry Pi Cooling Fan
Good morning all. My Raspberry Pi 4 is noisy, I am sure it is the cooling fan. Is it a simple procedure to replace it, and does anyone know the size/part number and where to get them from? And if I switch my Pi off will the solar system revert to the previous settings with the Axpert Inverters? If I could know I had the correct fan motor I am sure it will be a quick job.
Morning Paul,
Pi Fans do differ ever so slightly from case to case, so depending on the Pi case in question, it might differ slightly, but most are 25X25 X 7mm 5VDC
R
I installed a resistor in the wire to the fan. The noise level is a lot better and PI temp at 46 C.
