March 29, 20215 yr Greetings all Any guidance on the settings for the above. I have purchased 4 x 2.4 Pylontech batteries and need some technical assistance with setting up my inverter for these new batteries. My inverter details is as follows: Mecer Axpert Model Name: SOL-I-AX-5P Rated Power: 5000VA / 5000W DC Input: 48VDC, 117A AC Output: 230VAC, 50Hz Please may guidance be provided for settings so that I may update my inverter to accommodate the batteries which are set up in parallel. Thanks in advance
March 30, 20215 yr 17 hours ago, Skips said: Any guidance on the settings for the above. I have purchased 4 x 2.4 Pylontech batteries... I wish I had a dollar for every time I've posted this image. In your case, setting 02 would be 100 A.
April 10, 20215 yr On 2021/03/30 at 3:31 AM, Coulomb said: I wish I had a dollar for every time I've posted this image. you're too vague, here, if you're not careful, some jester from this neck of the woods will send you boatloads of Zim dollars... it won't make you happy... too low quality for toilet paper and no value otherwise...
