Axpert USB
1 hour ago, Venno said:
Is there another communication channel --Rs232 maybe
Yes. There is a comms port, disguised as an RJ-45 connector (usually used for networking). Use the provided RJ-45 to D9 cable, and the D9 is standard RS-232. Or make your own cable; it's a non-standard pinout.
Also is it normal for the inverter to go to grid when the solar power in is Zero even if it has not reached the setting bin program 12
If the battery voltage gets to 2.0 V above the battery low cutoff setting (setting 29), it acts the same as hitting the back-to-utility setting (setting 12). The battery voltage has to climb to the cutoff setting plus 4.0 V for the battery to no longer be declared "low". These thresholds are divided by 4 (so 0.5 and 1.0 V) in the LFP flavour of the patched firmware.
So just adjust down the battery low cutoff setting.
If the output source priority (setting 01) is SOL, then with zero PV the inverter will switch to grid power by design. If you don't want this (to keep your battery charged in readiness for blackouts), then use setting SbU (Utility last).
  • Replies 83
  • Views 29.8k
  • Although the chip is made by Cypress and it is indeed one of their RS232 -> USB converters, it has multiple operating modes. Mode of operation is determined by how they configured it during ma
  • Hi all, this is my first post in this forum. Thanks Gnome for your effort. I got your code (Python) and I begun to work with it.   I installed crcmod library for python (https://pypi.py
  • Lindsay
    Lindsay
    Ok, so I seem to have it working now in Python 3. After Gnome mentioned the encoding and I skimmed the articles above I looked at the encoding and changed my original code, which was based on nik
2 hours ago, Venno said:
Hi All
Sorry if this is not the right topic but please advise
Complete new guy here needs some help with MECER 5kw comms
I have it hooked up to Raspberry pi -- USB  and am able to read QPIGS etc
the communication is very erratic with the inverter it hang while waiting for QPIGS to send the 110 bytes
It works most of the time but hangs after a period
I have even got a separate python program running the QPIGS and QMOD writing that to file and the web page reading the file, but it still hangs so I cant log consistent Data or display it on my page updated every few seconds
Is there a trick to this some of you guys seem to have solved this
I haven't got any problem reading my inverter.  You can try our script (hibrido_test) or our APP (Voltron APP). You're free to test both. If you've any problem with language, leave a comment.
The script auto detect port (/dev/hidrawX) and CRC
In this case (alpha version), you need to edit voltron.py and modify the port.
Edited by nikitto
thanks for the quick reply
@coulomb
Do you also have problems with it hanging or is it only me?
do you have a simple program for rs232 comms -- send qpigs and wait for answer  ?
@ nikkitto
I use your program to read I cant see you hidraw -- do i have to login to that site to see it ( hibrido test)?
thanks so far
@ nikkitto
thanks so far
We're using module timeout_decorator to exit from definition if there's some problem.
You've to install these programs:
$ sudo pip install crc16
$ sudo pip install timeout_decorator
To run program:
$ sudo python hibrido_test.py cmd1 cmd2
or
$ sudo python hibrido_test.py cmd1 cmd2 -R
You can send one or more commands at the same time. Also, with -R (repeat these commands every few seconds)
As I said, you don't need to setting port or CRC.
hibrido_test.py
Edited by nikitto
Just now, Venno said:
Thank you very much -- Iw am waiting to get access to the other site to download the files?
I attached the file in the post before.
Traceback (most recent call last):
  File "niki.py.py", line 79, in <module>
    r = comando('QPI')
  File "/usr/local/lib/python2.7/dist-packages/timeout_decorator/timeout_decorator.py", line 91, in new_function
    return timeout_wrapper(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/timeout_decorator/timeout_decorator.py", line 150, in __call__
    return self.value
  File "/usr/local/lib/python2.7/dist-packages/timeout_decorator/timeout_decorator.py", line 173, in value
    raise load
UnboundLocalError: local variable 's' referenced before assignment
Hi Nikitto
Hi  I get this error on QMOD   -- rest work well
Hi  I ran the following and it seems much better now
sudo chmod -R 0666 /dev/hidraw0
Do I have to run it every time I reboot
Thanks again
Try it again or maybe this command doesn't exist in your inverter.
$ sudo python hibrido_test.py QMOD
Thanks again
You don't need to change the directory permission, just use 'sudo'
Hi Nikitto
does not give error now that i ran that chmod it works every time previously it ran some times and some times not
not sure how to explain it seems to be working now
going to get it to feed my web page now
Thanks for your support
Any advise would be appreciated
I don't wait for an answer. It's not so  reliable that you can do that. I use a Node Red program written by a colleague. It accumulates packets till a carriage return is seen, then goes into a giant parallel switch statement that matches the various fields of the various command responses. Occasionally a response doesn't come; too bad, that's one lost data point out of thousands. Occasionally commands will mangle together in the inverter, and it NAKs them. Occasionally you get mangled responses; usually these don't fit the regular expression for the fields, but if they do, then you get the occasional glitch response. Again, one in thousands is like this.
Node Red has the advantage that you send commands separately from waiting for them, effectively in parallel. Actually, waiting isn't the right word, you get a message sent when a field is ready.
Hi Coulomb
I dont have experience with  NODE RED
Are you using USB or rs232 to comm with inverter
Thanks for the response  -- is you code proprietary ? would like to look at  it if not
thanks again to all
mine is working better now and I can control my main/grid better now
Oh, RS-232; USB is somewhat tricky.
It's not proprietary, but it's fairly specific to the needs of our system, with a LyteFyba BMS, for example. Also, it's not easy to publish the "source code" for Node Red, as it's a graphical language. We also really don't want to field requests to modify or maintain it.
I've got a mix with Python, microPython (nodeMCU), PHP, HighCharts, MQTT, MySQL, Telegram, ...
Hi Nikitto
Just some feedback wrt the file u gave me
Its working very very well now thank you very much
i write the output to a file and then whoever in the family open the page it only polls the file and does not try to reestablish comm with the inverter
thank you very much -- life saver
  • 6 months later...
On 2017/05/03 at 11:48 AM, Gnome said:
The block device doesn't allow reading more than 8 characters at a time. So read 8 characters at a time until you get \r or some timeout is reached.
I didn't post this because my testing was a command that was 8 or fewer characters IIRC. Only after did I realize that the limitation.
If you want cross-platform however (eg. Windows/*BSD/Mac/Linux/etc.), it is worth looking into HIDApi. It is a C library but both Python and Ruby using FFI makes it really easy to use. Or just use C++
JNI would be a bitch IMO. Wish Java had FFI as part of the standard lib...
Hi Gnome... Do you still have the Mecer 5kw MPPT module....0848107816 is my number.
  • 5 months later...
Hi, sorry to revive an old topic.
I have had to rebuild my Raspberry PI 2 with the latest "Buster" version of Raspbian and I now have to run the code in Python 3. Has anyone managed to convert this code to work in Python 3? I know that commands like ".encode('string-escape')" are no longer supported and, while I seemed to get it working without this, by returning as a byte array, the rate of failure is much higher than it used to be.
If I repeatedly query the inverter via USB every 15 seconds, around 1 in 10 queries result in a valid response. Most of the time I get either 0 response or the start or end of the returned value is garbage or missing, resulting in less data than expected for the QPIGS command.
Some help here would really be appreciated as I was up until 5am Sunday morning trying to get this to work and spent several hours on Sunday also trying to get it to work.
Can you post a code snippet?
Did you change your USB cable?
- I've had faulty USB cables lead to bad data
Is a single command working sometimes but not other times?  Or are only some commands working and others not? (this is actually important for a few reasons)
Hi Gnome,
To give some further background, my SD card in my Raspberry PI went corrupt and during rebuilding now 2 years on, some of the libraries for an ADS1115 that I also monitor now appear to only work in Python 3. Since I access both the inverter and the ADS1115 from the same script I am forced to upgrade it to run on Python 3.
When I had problems getting it to run in Python 3 I created a test script that just reads from the inverter. I then fixed it as best I could to run in Python 3, however as mentioned I only get a full valid response for around 10% of the time. Raspbian Buster does actually also support Python 2, so if I call this exact same script in Python 2 then it works around 80% of the time. My 2 years old script would also fail sometimes in Python 2 and I'd just retry and get a value.
So I'm pretty sure it's not the cable. I am only using the QPIGS command, calling every 15 seconds, I just need to read the current voltage, solar watts etc.
I'll have to post my code tonight. It's a bit hacked together to try anything to get it to work - first it wouldn't even run due to functions no longer supported in Python 3, then I was either getting errors or no response, so getting it to 10% was actually an improvement 😕
I'm also going to try run the hibrido_test.py posted above.
Thanks!
If all you want is to run commands on the inverter, I also have something available you can use:
curl 'https://raw.githubusercontent.com/voltronic-inverter/web/master/raspberry-pi/install.sh' | bash
sudo reboot now
More details in the README
Thereafter you'll get the same result by just doing an HTTP call.  Very easy to write in Python, Bash, etc.
curl -X POST -d 'QPIGS' 'http://127.0.0.1:8080/voltronic/usb'
^ HTTP Post to localhost, the post content is the command and if the response is 200, then that is the data.
If the response is 500, it'll contain the reason for the error. 400 error response will indicate some form of client error.
Hi Gnome,
Thanks!
If you are adamant about getting your script working, you would need to post some code snippets, but IMO the most likely issue you are running into is python is trying to do some kind of character encoding on the response.
Your input I assume is a fixed string: QPIGS<CRC>\r
So that should really be consistently correct.
sudo reboot now
This is cool, will check it out.
Yes, I am still to get home and post some code ;)
But I am using QPIGS as you mention. I see the the file handling and character encoding changed between Python 2 & 3, I found a couple of resources to look at:
https://portingguide.readthedocs.io/en/latest/strings.html#file-i-o
https://medium.com/better-programming/strings-unicode-and-bytes-in-python-3-everything-you-always-wanted-to-know-27dc02ff2686
https://docs.python.org/3/howto/unicode.html
https://realpython.com/python-encodings-guide/
So this is probably the issue!
