Wiring advise: Deye 8K Inverter + 2 Shoto 5.12kWh LiFePO4
Hi All,
Please can you assist me with the correct wiring of the the setup mentioned.
To avoid you having to edit photos, I added labels to assist in making the links. (You're still welcome to edit and post again)
eg: A - B, C - F etc. Please also add the dip switch configuration.
MANY thanks!
Let me give this a shot!!
First, setup Battery P1 as master thus A = 10000000
then Battery P2 is slave, thus I = 01000000
(or as instructed by the manual)
Can cable (supplied with Inv): Q - B
Next ordinary LAN cable C - L
Next 2 interlinking DC (35mm2 - to handle >50A):
F - N (for +)
G - O (for -)
DC supply to Inverter (70mm2 - to handle >100A)
Note: Both pairs of cables to be the same length
(For +) S - E (and via 200A fused breaker a la Keto or Jean Muller)
(For -) R - P (and via 200A fused breaker a la Keto or Jean Muller)
Note: Do not connect + & - to the same battery, else one battery will always work harder than the other
Optional for monitoring (if you don't have the new dongle - not the Wifi one): The SunSync support is, not sure if the Deye does, seeing they are "brothers"
From RS485 to RPi with RS485 to USB cable
From Rs485 port D on Battery P1 to RPi with RS485 to USB cable (also optional, else you can use the inverter values)
This obviously requires a RPi (3B+ or higher) with good USB PSU
solar-assistant software.
Enjoy
"Note: Do not connect + & - to the same battery, else one battery will always work harder than the other"
Reading this note ... Should the + from the battery not be connected battery 1 and the - cable from the fuse be connected to battery 2 ?
  • 4 months later...
  • 4 months later...
What about the dip switch setting? I have put them to 10000000 on the first and 01000000 on the second battery, but my Deye doesn't pick up the BMS of the batteries. So for now I run them on voltage, knowing that this is not ideal.
Did you restart the batteries after changing the dipswitches?
  • 5 weeks later...
