December 23, 20214 yr Author 10 hours ago, PowerUser said: That depends on your battery. What is the battery brand and model? Whoops I see I wasnt very clear with my post, I meant that setting is how much power can be pulled and wasnt asking how much could be pulled...but seeing as we are on the subject 🙂 I have an Alpha ESS 10.1kw battery
December 23, 20214 yr 53 minutes ago, MakoShark said: Whoops I see I wasnt very clear with my post, I meant that setting is how much power can be pulled and wasnt asking how much could be pulled...but seeing as we are on the subject 🙂 I have an Alpha ESS 10.1kw battery If I'm looking at the correct spec, the charge/discharge current for that battery is 100A, which means the battery is 0.5C, so you should be able to pull around 5000W from it.
December 23, 20214 yr Author 40 minutes ago, PowerUser said: If I'm looking at the correct spec, the charge/discharge current for that battery is 100A, which means the battery is 0.5C, so you should be able to pull around 5000W from it. Thanks! Yeah I have it set as that, I have seen it get close to that so will leave it as that
December 30, 20214 yr Author OK so there is a max inverter W you can set under the work mode 2 settings page. Default is 5000w but if the inverter is rated to 5500w then why not set that? Anyone tried that or will it reduce the life of the inverter if it frequently provides over 5000w of ac? Edited December 30, 20214 yr by MakoShark
February 12, 20224 yr I installed a 8kw sunsynk inverter. On the display it shows comm error. It wont work at all. Any help would be appreciated please
February 13, 20224 yr 15 hours ago, CBurger said: I installed a 8kw sunsynk inverter. On the display it shows comm error. It wont work at all. Any help would be appreciated please Could you post some pics of the settings
March 20, 20224 yr On 2022/02/13 at 1:02 PM, Leshen said: Could you post some pics of the settings Hi. Thx for yr reply. Got sorted. Unit was faulty. Thx
