Shoto 5.12Kwh BMS to computer cable
  • Replies 103
  • Views 39.7k
  • Updating here as I have finally managed to get the 2 wire USB-RS485 adapter working with my shoto. Thanks to @jetleewho gave me the names of drivers that worked for his Narada battery on another topic
  • I'm just going to put some screenshots of all the default BMS settings here for reference and for anyone interested who doesn't have comms set up...
  • Yeah, the BMS is quite an impressive machine. I calibrated the time a few times, but it always seems to be out so I stopped bothering. The balancing is passive so it burns off the charge in the higher
On 2024/04/05 at 8:40 AM, ndondozz said:
i have problem with battery monitor on shoto battery
when i click on "conect" its apear time out
i use usb to rs485 with 5v+ A B Gnd pin
It could be a few things... check your baud rate, try switching the A and B wires around, otherwise it could be windows drivers.
Hi guys,
I have Shoto SDA48-100 battery, but this one don't have CAN bus, so I was unable to connect it to inverter.
Now trying at least to conecct it via adapter to the PC, but again no success here. Battery management software is only able to read manufacturing data, so it correctly identify model of the battery and manufacturer, but can't get any other data. The most strange thing is protocol version which is identified as 2.6 while everywhere else I only see 2.0 version.
By any chance is there anyone else with this battery who was able to read BMS data?
Giá hủy diệt] Pin Lithium Shuangdeng Shoto SDA10-48100 51.2V 100Ah- 5Kwh  MỚI 100% Chính Hãng [Có sẵn] | Lazada.vn
  • 3 months later...
