January 10, 20224 yr Hi All! I hope you're having a great day. Has anyone had any experience in using the BMS Communication Box found here (Raru) and many other places? RCT - BMS Communication Box for Using Lithium Batteries On RCT Axpert Inverters | Raru I have a BSL Lithium battery, and an Axpert 5kVA RCT-AXPERT 5K (running firmware 73.00e). I would like the inverter to talk to the battery, but don't want to purchase if it won't achieve this. Thanks so much in advance!
January 10, 20224 yr 1 hour ago, Trick720 said: Has anyone had any experience in using the BMS Communication Box found here (Raru) No experience with that box. My guess is that it's a clone replacement for the removable display, as used by later models. Your (and my) inverter with 73.00e can't talk to those displays. So save your money.
January 10, 20224 yr it seems to be for these models =>RCT-Axpert 5K MK2 and RCT-Axpert 5K (PF1.0 Model with firmware update), thats the extent of the info anywhere. Edited January 10, 20224 yr by Nitrious
December 25, 20223 yr On 2022/01/10 at 1:48 PM, Trick720 said: Hi All! I hope you're having a great day. Has anyone had any experience in using the BMS Communication Box found here (Raru) and many other places? RCT - BMS Communication Box for Using Lithium Batteries On RCT Axpert Inverters | Raru I have a BSL Lithium battery, and an Axpert 5kVA RCT-AXPERT 5K (running firmware 73.00e). I would like the inverter to talk to the battery, but don't want to purchase if it won't achieve this. Thanks so much in advance! Did you buy the box or not? Did it resolve your issue?
