January 21, 20224 yr Hello All First post here - a wealth of knowledge on this site and it has helped me make a somewhat informed decision. We have a solar geyser, gas hob and LED lights in our house. I would like to install a system to beat load shedding for the 2.5 hours when it happens. I calculated our max load of 1800W excluding pool pump, geyser, irrigation, gate motor, oven, etc. At any time, I think the typical draw would be about 1200W. Most important is our fibre routers and work server that needs to be up. No need to run the pool pump, etc during load shedding - I will split the dB. I am keen to go for the Kodak VMIII inverter and pylon US2000B kit from this site. It is a 24V system. It will also allow me to add a few panels later. My budget around R25k. My understanding is that the VMIII system allows 'blending' of power. For example, if I had solar panels, it can be set to first use the solar power and then make up the shortfall from the utility. Is my understanding correct? I would like to add some panels at a later stage. Any better ideas on how to spend R25k? Thanks in advance.
January 22, 20224 yr 23 hours ago, shazybug said: My understanding is that the VMIII system allows 'blending' of power. Yes.
January 22, 20224 yr the Pylontech 2000 is a 48 volt battery, you need the Pylontech 2500 Edited January 22, 20224 yr by Tariq
February 16, 20224 yr You will need 2 Pylontech batteries. The maximum charge/discharge on them is only 1300w (55amp on 24v dc). So you’ll have to fit 2 of you need 1800w at some stages.
