Raspberry Pi
euhm not sure about that...my inverter can show pv1 and pv2 separated and total on the display
when i looked in your program..that was the exact value of my PV1 on the inverter... not the combined voltage and watts
the protocal doc you have is for the MS version, and that is indeed a single MPPT solar input, i have dual remember default_wink.png
If you can supply me the correct protocol doc then i can help you
  • Replies 189
  • Views 56.2k
  • Hi All. Manie Helped me set up ICC remote dashboard this morning and after previous failures to get AICC working i am very happy. Manie was quick to offer help to get it set up and I'm more than
  • Hi Frits, sorry for only replying now but I only received the tapatalk notification. I also ordered a pi after first hearing about it on the old aicc website. I installed it, got it working, but it
  • hoi,    the update from the test version i had for the pip4048msd is not that big of a diff. BUT its an update that is good and stable!   in general i am very very happy with
you have mail with the msd protocol, i"ve found it on the i-net ,
there is protocol of MSD (dual) and the MST (triple)
thanks brother !!
22 hours ago, PeterGutti said:
11 hours ago, plonkster said:
Indeed, I found that out this morning. There is something called dtruss that looks like it does the same thing, but it needs elevated privileges (on Linux it doesn't). Anyway... probably a wild goose chase anyway.
hi plonkster, after unmounting the SD the dd semms to work... seems because it did not come up with an error msg, it just stays ... i do not see any sign of action.  I wait until tomorrow morning.. will report back.
4 minutes ago, PeterGutti said:
Don't we have now multiple discussions in parallel?  It is confusing me ...
Sorry i don't understand ?
May be i'm not clear about how this forum is setup: Under "Raspbery Pi" heading various discussions to different subjects are going on: dd busy.. axpert return string, .. That makes it difficult to follow a discussion. Thats all.
Yes we are trying to add another inverter. We did not have the protocal document. If you look at you threads page. You will see a return string.
Currently this is the only forum were we can discuss it. Yes I agree with you
Maybe we should add anorher section onder ICC
7 hours ago, Czauto said:
Julle het my lankal verloor[emoji85]
Sent from my S60 using Tapatalk
Sorry. Yes some of the questions should be in its category
If you need more clarity pm me
@Manie: The downloaded the emon pi package and, i think! (dd never ended, had to break) "burned" it to SD card.  IP scan returnes an IP address i use to "ssh [email protected]".  But now the password "raspberry" is not accepted.  Why?
On 10/1/2017 at 9:19 AM, ebrsa said:
Peter the file is almost 3GB. I am using a file downloader program just in case the connection breaks and I have to start again. At least it then starts where it stopped. The download time for me is about 2 hours. You may like to try the same if you are not already doing so.
ebrsa, thanks für the hint. Now i have the image installed and i think it boots up. But the password is not accepted.. Is it not "raspberry" as one would expect?
Hi password for jessy or emoncms
The username is stil pi and the password is raspberry for raspbiam
For local emon username is ICC and pasword.is raspberry
Manie, no luck up to now.  I connected a monitor and can now see what is going on:
  • A full screen character based screen, prompting for login: emonpi  login:
  • as login (user ID?)  i tried pi and ICC
  • as password i used for both IDs raspberry
Response always is: Login incorrect
Let me check here by me, i will report !
I just tried now I login in as ICC and password raspberry. Pm me if you still needs help
I double checked: ICC/raspberry returns "Login incorrect"
The character fullscrren prompt is correct? No GUI?
..while starting up i see a lot of messages, most of them with OK in front.  But minimum 3 messages signalling a failure also fly over the screen.  Are they all logged in a file?  Should i ever be able to login, a can forward it to you.
Edited by PeterGutti
file attached
Please do. If you have teamview i can try and help and see what you mean
yes we can
Pm me please !
