January 6, 20179 yr Hi Guys The raspberry pi project will continue, however the naming will be different. I will handle everything alone at this stage and will continue developing for both the pi and the remote desktop application. The following inverters are supported: Axpert 3 kva Axpert 5 kva Axpert 5 kva (cluster) up to 6 inverter Infini 3kw Infini 5kw Infini 10kw Infini v series 4kw Inini v (cluster) up to 6 units. The battery monitor will still be added to read all battery temperatures of each battery and also , each voltage and so on. I will do the testing and the coding will be added to ICC. The unit can be ordered. I will support the coding for the unit and the unit by someone else who is the developer. Will give more details when we finish with the unit and coding added to ICC AICC is no more for the raspberry pi inverter software.
January 6, 20179 yr 9 minutes ago, Manie said: AICC is no more for the raspberry pi inverter software. Do you mean AICC as a name/brand!?
January 6, 20179 yr Manie this is all good news. I noticed that AICC for the RPi was no longer available on the aicc.org.za website and the Tinkercity website closed down. It certainly raised some concerns about the program which is a crucial component of all user's Axpert installations. I assume that you will in time create a website to handle the product without which I will be between a rock and a hard place. Long live ICC. Could you post some details and price of the battery monitor when available please.
January 6, 20179 yr @ebrsa Yes I will create a web site. As soon as the device is ready, i will give you the price. I will build in all the value for the user in the inverter app and upload the data to emon. to read each temperature and volts of each battery will be awesome. You can quickly also detect if there is a bad battery in your bank and have some history about them.
January 6, 20179 yr Hi I have added the pv trends and amps charts to ICC Remote MQTT http://iccsoftware.co.za/download-2/ For any keys, send me a Pm Regards
January 7, 20179 yr Manie My ACII stop working, says key no valid. I did upgrade my PI. How do I get it fixed
January 7, 20179 yr Also.... this old coder is curious to know how you identify the hardware, whether it is by looking at the serial number in /proc/cpuinfo or similar, or perhaps the ethernet address of the hardware. That last one would explain why it might stop working, I noticed in newer distros the ethernet device naming changes from ethX to enp0sX or something like that. Apparently this renaming is a udev thing rather than a kernel thing. Anyway, I'm guessing. Hopefully Manie will tell us shortly.
January 7, 20179 yr Hi Guys. Started Toying with this myself, Thanks for all the hard work Manie and Co. Is there a Dev forum like github for this or are you guys doing closed dev? Insignificant note: Title Bar shows v1.3 Download shows V1.5 not that it matters ;-) Is Beta testing Closed? Can provide remote SSH,Vnc or so forth to the unit if you guys want, also running 5kva mks x2 currenly in Master/Slave Config (PAR)
January 7, 20179 yr 1 hour ago, twmuller said: Manie My ACII stop working, says key no valid. I did upgrade my PI. How do I get it fixed Sorted.
January 7, 20179 yr 13 minutes ago, Cybertza said: Insignificant note: Title Bar shows v1.3 Download shows V1.5 not that it matters ;-) Hi Sorry i lost you there, what bar ? Regards
January 7, 20179 yr 23 minutes ago, plonkster said: Also.... this old coder is curious to know how you identify the hardware, whether it is by looking at the serial number in /proc/cpuinfo or similar, or perhaps the ethernet address of the hardware. That last one would explain why it might stop working, I noticed in newer distros the ethernet device naming changes from ethX to enp0sX or something like that. Apparently this renaming is a udev thing rather than a kernel thing. Anyway, I'm guessing. Hopefully Manie will tell us shortly. Hi Plonkie Why it wil stop is because he closed down the site where i looked for updates. The site does not exist anymore
January 7, 20179 yr Just now, Manie said: Hi Plonkie Why it wil stop is because he closed down the site where i looked for updates. The site does not exist anymore Cool, but can you tell me how it identifies a particular board (or is that super secret proprietary stuff)? :-)
January 7, 20179 yr 17 hours ago, Manie said: ttp://www.mediafire.com/file/snw54v4w5w18ovg/ICC_MQTT+V+1.0.5.rar Hi Title Bar at the top of the program that i linked here - the remote client - above the connect to address name. at the bottom it shows the right value. Its honestly just cosmetics ;/ Just noticed it. That's why i asked if there was a Dev/Beta Forum to rather mention these little insignificant things :-) Busy installing (a)ICC.Pi now
January 7, 20179 yr 1 minute ago, Cybertza said: Hi Title Bar at the top of the program that i linked here - the remote client - above the connect to address name. at the bottom it shows the right value. Its honestly just cosmetics ;/ Just noticed it. That's why i asked if there was a Dev/Beta Forum to rather mention these little insignificant things :-) Hi Thanks i did not even see it. You have a very sharp eye. I am still setting up the website
January 7, 20179 yr 1 minute ago, Manie said: Thanks i did not even see it. You have a very sharp eye. I am still setting up the website For the (a)icc.pi install? I have an rar file here that points to me having to download stuff off the aicc website, so i take it my progress will be hindered at that point? Let me know if you guys still need beta and so forth. Willing to help where i can.
January 7, 20179 yr I am almost done with the image for new users. They can just download , burn and everything will be installed. Also local emoncms At this stage i am working alone. I will sort everything out and make it more easier. Regards
January 8, 20179 yr Hi All. Manie Helped me set up ICC remote dashboard this morning and after previous failures to get AICC working i am very happy. Manie was quick to offer help to get it set up and I'm more than happy to pay for the software license. I'm sure there will be some upgrades soon maybe there should be a sticky on the forum on suggestions people would still like to have integrated into the software. I don't think all suggestions would be viable but I think it might be a good idea to hear others thoughts to make a great program even beter. I know there was a discussion on the Tinkercity website before it closed down. Thanks for the help Manie. Appreciated!
January 8, 20179 yr I am still busy with the site, but you can download from there http://iccsoftware.co.za/ Regards
January 9, 20179 yr i'm currently downloading ICC-PI.rar (slow). Does this pakage contain all that is needed? including the OS. So i don't have to install NOOBS?
January 9, 20179 yr You dont have to install anything. Everthing is installed. I also installed local emon Just download and burn it to the sd card and start it up
January 10, 20179 yr Peter the file is almost 3GB. I am using a file downloader program just in case the connection breaks and I have to start again. At least it then starts where it stopped. The download time for me is about 2 hours. You may like to try the same if you are not already doing so.
