April 1, 20224 yr Hi Guys, I just want to find out, if this inverter is connected to grid what is the max AC passthrough current it will handle? I know if there is no grid connected its 5kw but what can it handle while on-grid? Ive had this inverter for just over 3 months and today was the first time it had an AC overload issue and the grid was connected and on and I think the house was demanding about 6 kw, i thought it would just blend the rest from grid? Edited April 1, 20224 yr by MakoShark
April 1, 20224 yr It can passthrough 35A IIRC. Overvoltage is something else and does not depend on the load so much.
April 1, 20224 yr Author It was an AC Overload fault if that helps Edited April 1, 20224 yr by MakoShark
April 1, 20224 yr In that case the load had to exceed 35A. An induction motor can easily push you over that threshold - my lawnmower draws 32A for 1.2s on startup.
