Lithium Battery Settings
Hi there I hope someone can help. I have hijacked my husband's profile as he is away. I have a Mecer (Axpert) 5kva inverter but have just upgraded to a 100a/h lithium battery. No solar at the moment. I just need some advice about settings on the inverter. I added a screenshot of my settings as the installer wasn't 100 percent sure what to change. Do I need to make any changes? Any help would be greatly appreciated.
Linda
45 minutes ago, TrevorH said:
Thank you I will check with the installers.
The only info I have is that it is a 100ah 48v Leoch Battery.
You can confirm on the Averge Web if their battery is the same as yours. They do have some limited specs there.
Corrected name
I have the same batteries. My settings are pretty much the same except for floating charge voltage 52.5V.
It just comes to my mind: Did your battery come in a box with instruction manual, communication and battery cables and a CD? If not and they are black ask the seller for his invoice from Averge. These are the type of batteries that are getting stolen by criminals from cellphone towers and put on the market. I got delivered such from my installer. When I found out I required him to take them back and refund me. I then purchased new ones from the importer Averge. The installer got inquired for criminal charges and is now out of business.
Edited by Beat
