September 23, 20223 yr Please help. They installed our Luxpower inverter but the electrician does not know this brand. Now problem is that the inverter runs only from the battery, once battery is depleted, it charges it from eskom until 100 % and when charged it uses again the battery. It does nog switch over to only eskom once power is on to use inverter as the reserve. How can we fix it
September 23, 20223 yr 2 hours ago, Natalie said: Please help. They installed our Luxpower inverter but the electrician does not know this brand. Now problem is that the inverter runs only from the battery, once battery is depleted, it charges it from eskom until 100 % and when charged it uses again the battery. It does nog switch over to only eskom once power is on to use inverter as the reserve. How can we fix it My advice will be to read the manual. Inverters have so many settings one must ensure all is set as required. There is no way a sparky who does not know the inverter will get it right without looking in the manual.
September 24, 20223 yr 15 hours ago, Natalie said: Please help. They installed our Luxpower inverter but the electrician does not know this brand. Now problem is that the inverter runs only from the battery, once battery is depleted, it charges it from eskom until 100 % and when charged it uses again the battery. It does nog switch over to only eskom once power is on to use inverter as the reserve. How can we fix it Pop me a DM if you need help Natalie, I had the same issue and went through and watched the LuxPower training material on YouTube to slowly learn everything Basically you need to do what I did in my post above and set the AC Charge time correctly. I can assist. Edited September 24, 20223 yr by Soprono
November 23, 20223 yr Please Assist! I Installed a Luxpower SNA 5000 Hybrid and is very happy. When my system is running and the sun is shining the switch over is very fast when there is load shedding. The problem is when cloudy or at night and there is load shedding then the switch about 2 to 3 seconds. Everything switches off and on again! Please help?
January 18, 20233 yr Every morning when there is load shedding overnight my luxpower inveter is always off meaning the lines on the inveter do not show , I always have to reset the whole system , then iam good to go ...what could be wrong?
March 1, 20233 yr My cell number is +27 [redacted by mods]. Is there anyone who can help with wifi settings for luxpower Edited March 1, 20233 yr by Moderator2 personal cell number redacted
March 1, 20233 yr 38 minutes ago, Mikeson said: My cell number is +27 [redacted by mods]. Is there anyone who can help with wifi settings for luxpower Your number has been redacted for your own safety's sake. Please do not share personal cell numbers on the public form, rather use a DM.
