Beta Tester O N L Y AXPERT MAX 7.2KW MPPT improvement
hello i have 2 7.2 kw that i want to parrallel but the firmware is not the same can you please help with firmware that i can install on both to get it working
  • Replies 143
  • Views 21.6k
  • This is patched firmware version 245.11, based on factory firmware version 45.11 for the Axpert Max E 7.2kW '2809. It implements Georg's MPPT patches, with a minimum MPPT voltage of 120 V (since earli
  • Second  BETA  release still untested   changes : mppt min voltage 100V 7.2KW.zip
  • see here: https://forums.aeva.asn.au/viewtopic.php?p=87767#p87767
On 2024/09/25 at 6:48 PM, jako123 said:
hello i have 2 7.2 kw that i want to parallel but the firmware is not the same
Please post the present main (U1) firmware versions. There are two different chipsets involved, and  it's vital to get the right one.
It's also possible that the firmwares are close enough that they will work with each other.
Can i sent my chipset and firm ware aswell i also want to Parralell but firm ware are different?
17 hours ago, jvrenspa said:
How do i get the chipset version?
I sow it somewhere in the trend but can't find it now.
Press the up or down arrow buttons on the inverter until the top row shows "U1", then reply with the numbers on the middle and bottom row. My inverter shows:
U1
69
61
You may be thinking of this thread:
But you don't need to open your inverter to find the chipset; just posting the main (U1) firmware versions tells me the chipset anyway.
Old inverter:
U1 90 28
U2 12 13
U3 00 00
New inverter
U1 69 07
U2 12 21
U3 00 00
9 hours ago, jvrenspa said:
Old inverter:
U1 90 28
That firmware is quite old; Sep 2021. '2809 chipset. Normal firmwares for this model are 45.xx. They don't seem to have used that processor in this model lately, since the latest in this series is 45.62, Nov 2022.
U1 69 07
September 2023. '28066 chipset. So you can't have the exact same firmware in both. The closest in hex file date stamp is 69.62 from Dec 2022, 11 months earlier. But the fact that the minor version number (62) is the same for both is a good indication that they will be compatible.
So my suggestion is to update 90.28 to 45.62, and to downgrade 69.07 to 69.62. These should be compatible. If you are irritated by a lack of features or introduction of bugs in 69.62, you could try going back to 69.07, or even to the latest 69.70 (Mar 2024), and I don't expect any compatibility issues, though it is possible.
I suggest updating the one display that is at 12.13 to 12.21, which is from the same era (Aug 2022).
I have to rush off; post if you have trouble finding these firmwares. I find that once you know the exact firmware version that you need, it's easy enough to find with a Google search (use the term "Axpert firmware" and the version e.g. "69.62".
Edit: I have a little more time now. I see that 69.62 is no longer available easily, so I'll attach it here.
This is factory main firmware version 69.62 for the Axpert Max E 7.2 kW '28066, and also for a split-phase model whose MPPSolar name is PIP-6548 LV. Do not use with other models. Hex file is dated Dec 2022, not the latest version; use only for paralleling with older models. Use at your own risk.
dsp 69.62 PIP-LV6548 split phase '28066.zip
Edit 2: I see that the same problem exists for 45.62.
This is factory main firmware version 45.62 for the Axpert Max E 7.2 kW '2809, and also for a split-phase model whose MPPSolar name is PIP-6548 LV. Do not use with other models. Hex file is dated Nov 2022, not the latest version; use only for paralleling with older models. Use at your own risk.
dsp 45.62 PIP-LV6548 split phase '2809.zip
Note for split phase readers (North American users only): When run in split phase hardware, the version number will likely not be the same as when run in single phase models. I don't have time at present to look up the numbers, sorry.
Edit 3:  Display firmware version 12.21 is available here.
Thank you i wil read and check this out my eng is bad. But i will get there soon... Thanks allot .
I use lead battery bank. 48v 930ah
24x 310w panels.
Thats the system.
Thank you
Hi, hope you are well.
I am back so; I must check if the cable I bout is the correct one.
Then I can update like you said here?
I am back so; I must check if the cable I bought is the correct one.
Certainly you need a good USB to RS-232 adapter to perform firmware updates, unless it's only a main firmware update, then you could  try the USB on-the-go cable method. To check the adapter, make sure that Watchpower runs through it. Make sure that you exit Watchpower properly (don't just close the window) before updating via RS-232.
Sure.
Sure.
Thank you,
Will check the cable that i got today if it work otherwise i will get the mercer one on Takealot.
Maybe there is a way to reset email on the old inverter? because the previous owner cant remember witch email he used to set up Watchpower .
i can not link to the old inverter with my phone.
Sorry, I don't use Watchpower. I can't think what it does with the email address, unless it's you send you an alert or similar.
  • 10 months later...
On 2023/01/22 at 6:29 PM, Georg594 said:
First Release for 7.2KW Axpert
Firmware still based on 90.19
It got the same improvements like my 8KW version except the Shade Management.
Mppt minimum voltage is set to 120V (the new range is 120V to 450V)
Firmware shows up as  90.20
7.2KW.zip
Is it error F90 defeated on this version?
  • 5 weeks later...
Looks like 90.19 to me.
No, it's "live" on this firmware.
P.s. sorry for the very late reply, a whole month after you posted. I've been really busy on another project.
Hello, thank you so much for your reply, ¿have you got or can you link me a firmware which have f90 bug defeated?
Thank you so much
Sorry for the extremely late reply.
I don't seem to have any 7.2kW patched firmwares that defeat fault code 90.
If you are still interested, please PM me with what minimum MPPT voltage you want, and I'll see what I can do.
Hello Guys, i have a 7.2KW inverter , Frimware version U1 - 45.07, can you help me with a firmware solving the problem of 90V ? I think ideal would be for 180 - 200 V .
Sorry i checked better the forum, can somebody confirm to me that i can flash the 245.11 over the 45.07, to fix the 90v issue ?
And another small question should i update also the display, or leave it as it is ?
Thank you for your help
Edited by BGD
Yes, that's the only 7.2kW patched firmware in the x45.xx series. Unfortunately, it's a bit old now, so it's a fixed 120 V minimum MPPT voltage, which may not be ideal.
There is no need to update the display firmware for this issue.
