February 10, 20233 yr All solved by removing com between inverter & batteries, using voltages only and living the BMS of each battery does its job : stopping charging but equalizing cells when batteries are full. Monitoring with Solar Assistant, all fine ...
December 27, 20232 yr On 2023/02/10 at 9:50 AM, zivva said: All solved by removing com between inverter & batteries, using voltages only and living the BMS of each battery does its job : stopping charging but equalizing cells when batteries are full. Are your Narada batteries still working fine without battery/inverter comms and just using voltages?
