please help
Daniel128
3 hours ago, ibiza said:
Mustek, but you can buy only through the register installer. if you are planning to go for infinisolar 4kw super forget it as Mustek doesn't want to import them any longer as they discovered "hidden"/ potential malfunction .
Hi Ibiza
Do you know what this hidden/potential malfunction entails. It would be good to know about it and determine under what conditions it occurs and perhaps find a solution.
If there is a problem and they know about it and do not warn their clients then even this woolly sheep-farmer knows that if taken to court it is a case they cannot win. Perhaps they should talk to Ford before the proverbial hits the fan.
