January 26, 20233 yr Anyone know what the administrator password is for PBMS tools in order to change a parameter setting on battery?
January 27, 20233 yr The password is stored in a .db file and not by the battery, so depending on where you downloaded it from and which entry it associated with your BMS, but most likely it will just default to the first entry, which starts in a 1 and ends in a 6. I'll leave the rest for you to work out ðĪŠ
January 27, 20233 yr 21 hours ago, brburger said: Anyone know what the administrator password is for PBMS tools in order to change a parameter setting on battery? 123456
March 4, 20233 yr 123456 worked for me, but I was unable to change anything on the parameter setting page. I can however change the capacity, charge cycles, serial number etc. Any advice on changing the cell balancing voltage from 3.5 to 3.45?
April 17, 20233 yr I can now edit the parimeters also. Make sure the decimal indicator in windows control panel is set to point(.)
December 8, 20232 yr Hi every body! Did you able to run the bms tool on windows10? I couldn't run due to .net error, (but windows included .net) then I fixed it by adding dll, and have i/o error on start. Please help me run this app. Thank you so much! Edited December 8, 20232 yr by Oleksii
June 7, 20251 yr Hi all, when I try to connect I get "No availible serial port".When I go to Device Manager, I see the usb serialAm I using the wrong rs232 cable?
June 8, 20251 yr What battery are you connecting to.? I got the same error trying to connect to my Sunsynk 5.32 batteries when using only the pins 1,2 and 3. It worked when I joined the wires together i.e. 1 and 8 , 2 and 7, 3 and 6.
June 8, 20251 yr Hi, freedomwon e-tower. On the rj11 I'm using pin 3.4.5 and on the db9 pin 2.3.53-24-45-5
March 10Mar 10 Where can I download the PBMS tool or is there someone who can make the most recent version available via DropBox, Google Drive or similar. I have calculated the number of cycles but would like to see it on the battery.
March 10Mar 10 7 minutes ago, SRTosen said:Where can I download the PBMS tool or is there someone who can make the most recent version available via DropBox, Google Drive or similar. I have calculated the number of cycles but would like to see it on the battery.Managed to find it in the downloads section.
