Daly BMS 16s 200a
Hi All
Just want to check I have recently put a 16s pack together with this Daly BMS but the strange thing is the current charge or discharge is irractic. Did any experience this?
Are you referring to the current displayed by the app? If so I have also noticed the fluctuations, which don't corresponding to the real values. Fortunately I don't reply on them.
Cheers
Ian
16 hours ago, John2 said:
Hi All
I have a 8s 100A Daly. Current display on app also irratic altough the current from the inverter to battery is normal when checked with clamp meter. Battery SOC also faulty , always 100% .
Edited by Chris Louw
4 hours ago, Chris Louw said:
I have a 8s 100A Daly. Current display on app also irratic altough the current from the inverter to battery is normal when checked with clamp meter. Battery COC also faulty , always 100% .
You should set max cell votlage to your charging voltage divided by 8s , then set balancing start at 3.0v with 0.02 deviation
Edited by Lipastas
