April 2, 20233 yr I'm selling a 3.5KWH Pylontech US3000, I used it for just over three years without any issues still in good condition, Reason for selling I wanted to upgrade and could not get another US3000 to parrallel,so I upgraded to a 6.4KWH BSL battery. Looking for serious offer. Alberton area.
April 2, 20233 yr Author I have'nt checked it, when I get a chance I will try to check, It should be in the region of about 600x cycles and 95%SOH
April 11, 20233 yr Correct me where I am wrong. If I understand correctly, the Pylontech's can mix, so you could have paralleled it with a UP5000. You would just make the UP5000 the master.
April 11, 20233 yr 9 hours ago, Superfly said: Yep... they are all 15s - so kwH makes no difference @Superfly, what do you mean by “15s”?
April 12, 20233 yr 12 hours ago, Muchachos said: @Superfly, what do you mean by “15s”? 15 cells connected in series, probably 3.7V each.
April 16, 20233 yr Author On 2023/04/07 at 8:38 AM, Don_CT said: What are you hoping to get for it? Sorry it is not available anymore.
April 17, 20233 yr On 2023/04/12 at 11:31 AM, Tim003 said: 15 cells connected in series, probably 3.7V each. Thanks
