June 14, 20233 yr Good day, I am a new to the group and wonder if somebody can assist. I came across three Tescom SSPro 5kva inverters, but on the side label it doesn't say what the max PV input is. Can anybody assist with the specs?
June 14, 20233 yr Hi The Tescom SSPro 5kva inverters do not have a pv input. Attached are the user specifications. 92114_PDF1.pdf Edited June 14, 20233 yr by Peter Topp
June 19, 20233 yr Author Hi Peter, Thanks for the reply. Please see attached. Maybe somebody can help.
June 19, 20233 yr 2 hours ago, Patrick Fleetwood said: Hi Peter, Thanks for the reply. Please see attached. Maybe somebody can help. You can work on around 50V*60A=3kW. Ensure that panel Voc does not go over about 130V at 25 deg C.
June 21, 20233 yr On 2023/06/20 at 2:43 AM, Scorp007 said: You can work on around 50V*60A=3kW. Or even up to 20% higher than that. So 3.6 kW max. Anything above that and the solar control algorithm, which is not the best, will overshoot badly and potentially damage your battery.
