June 15, 20233 yr Hey, I am just wondering if anyone has run into this and perhaps found a solution... So this is a Deye 10kW 3P, connected via the BMS with a splitter to SolarAssistant. But it keeps giving a CRC error: The unit is reading and everything seems fine but it keeps giving this error and I cant seem to get it to go away... Anyone else seen this?
June 15, 20233 yr 1 minute ago, Psy said: Hey, I am just wondering if anyone has run into this and perhaps found a solution... So this is a Deye 10kW 3P, connected via the BMS with a splitter to SolarAssistant. But it keeps giving a CRC error: The unit is reading and everything seems fine but it keeps giving this error and I cant seem to get it to go away... Anyone else seen this? Might be something with the splitter - what happens if you take the splitter out of the equation and connect SA to the inverter?
June 15, 20233 yr Author Thanks for the help. it keeps giving the same issue... My concern is that is has something to do with the settings on the inverter but I am a complete noob when it comes to Deye inverters, never dealt with them too much in the past. Edited June 15, 20233 yr by Psy
June 15, 20233 yr Is the battery on RS485 too? If so, this is expected - the RS485 has no negotiation for shared masters, it only generates CRC errors and expects the masters to retry.
