September 6, 20232 yr I have been using the Efegy meters for a number of years as a way to first survey a site as to the load usage etc. It was quite a good tool for that purpose and very cost effective . The original ones I bought directly from England and then the Ellies branded versions appeared locally and I used those very successfully . Then Ellies discontinued the importation . I have used them on individual phases and on 3 phase systems . They are now unobtainable - what alternatives are available ? This is specific for the use of temporary measuring the load at a site . regards
September 6, 20232 yr 1 hour ago, 1ougat said: I have been using the Efegy meters for a number of years as a way to first survey a site as to the load usage etc. It was quite a good tool for that purpose and very cost effective . The original ones I bought directly from England and then the Ellies branded versions appeared locally and I used those very successfully . Then Ellies discontinued the importation . I have used them on individual phases and on 3 phase systems . They are now unobtainable - what alternatives are available ? This is specific for the use of temporary measuring the load at a site . regards I am sure @TaliaB will provide you some pointers.
September 6, 20232 yr 1 hour ago, 1ougat said: I have been using the Efegy meters for a number of years as a way to first survey a site as to the load usage etc. It was quite a good tool for that purpose and very cost effective . The original ones I bought directly from England and then the Ellies branded versions appeared locally and I used those very successfully . Then Ellies discontinued the importation . I have used them on individual phases and on 3 phase systems . They are now unobtainable - what alternatives are available ? This is specific for the use of temporary measuring the load at a site . regards You can still buy them at GeeWiz: https://www.geewiz.co.za/gadgets/62551-efergy-standalone-home-hub-solo-with-power-supply-only-electricity-energy-power-monitor.html https://www.geewiz.co.za/gadgets/62551-efergy-standalone-home-hub-solo-with-power-supply-only-electricity-energy-power-monitor.html https://www.geewiz.co.za/smart-home-accessories/187419-efergy-emax-smart-home-wifi-kit-wi-fi-screen-app-electricity-energy-power-wattage-monitor-watt-meter.html
September 6, 20232 yr 3 hours ago, BritishRacingGreen said: I am sure @TaliaB will provide you some pointers. @1ougat I use IAMMETER for my temporary energy measurements. They are versatile and user-friendly available in single and 3 phase with cloud base server with live results on smarthone or pc. They are available in 150A, 250A or 400A split core ct. https://www.iammeter.com/ https://www.sustainable.co.za/products/iammeter-bi-directional-single-phase-wifi-power-meter-150a?variant=44143108161776¤cy=ZAR&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjwxuCnBhDLARIsAB-cq1roitYQGoc855W1Tqb2uj7VKflMAt4XUnDxM1eV7_ms63tnou2htDoaAm6-EALw_wcB Edited September 6, 20232 yr by TaliaB Corrected ct sizes
September 6, 20232 yr 11 minutes ago, TaliaB said: @1ougat I use IAMMETER for my temporary energy measurements. They are versatile and user-friendly available in single and 3 phase with cloud base server with live results on smarthone or pc. They are available in 150A ct or 500A ct. https://www.iammeter.com/ https://www.sustainable.co.za/products/iammeter-bi-directional-single-phase-wifi-power-meter-150a?variant=44143108161776¤cy=ZAR&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjwxuCnBhDLARIsAB-cq1roitYQGoc855W1Tqb2uj7VKflMAt4XUnDxM1eV7_ms63tnou2htDoaAm6-EALw_wcB This is a great gadget. I like the bi-directional side.
September 7, 20232 yr Author 13 hours ago, TaliaB said: @1ougat I use IAMMETER for my temporary energy measurements. They are versatile and user-friendly available in single and 3 phase with cloud base server with live results on smarthone or pc. They are available in 150A, 250A or 400A split core ct. https://www.iammeter.com/ https://www.sustainable.co.za/products/iammeter-bi-directional-single-phase-wifi-power-meter-150a?variant=44143108161776¤cy=ZAR&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjwxuCnBhDLARIsAB-cq1roitYQGoc855W1Tqb2uj7VKflMAt4XUnDxM1eV7_ms63tnou2htDoaAm6-EALw_wcB On the 3Phase meter can you still see the individual phase details or is it combined in one reading/ graph?
September 7, 20232 yr Hi All, chatted to Geewiz and they recommend this product - https://www.geewiz.co.za/home-electronics/192515-emporia-vue-gen-2-energy-monitor-with-2x-200a-sensors.html as I wanted to monitor 3 different cables - main house, flat 1 and flat 2 - Need to add an extra sensor. Thoughts on it?
September 7, 20232 yr 6 hours ago, 1ougat said: On the 3Phase meter can you still see the individual phase details or is it combined in one reading/ graph? You can see each phase separately so you can detect unbalanced load connections per phase.
