August 26, 20188 yr hi guys am I reading this right at about 8ish your batteries are at about 25% soc . does that mean 75 % depth of discharge ? what are the cable sizes from the panels . thin bad thick is good just asking cheers
August 26, 20188 yr Author On 2018/08/22 at 8:45 PM, Antony said: I see your 6:30am load for your kettle is the same as mine ;-) Just over 2kW Hey Antony! Yeah there is a spike but that isn’t the kettle. It is my wife with her ninja hair dryer! Hehe
August 26, 20188 yr Author 44 minutes ago, maxomill said: hi guys am I reading this right at about 8ish your batteries are at about 25% soc . does that mean 75 % depth of discharge ? what are the cable sizes from the panels . thin bad thick is good just asking cheers Maxomill, Yes it was at 75 DOD at 8:30. At this stage I am basically relying a lot on the batteries through the night. My meter is basically dead and doesn’t move. I will need to increase the bank a bit as to not get such a huge DOD. It also compensated for any grid use, such as the wine fridge and aircon unit. It is doing what it says on the tin.
August 26, 20188 yr I have a v series which I run in self consumption mode does the goodwe not have that or at least a swap back to Eskom maybe as batteries are expensive thanks for the great info interesting reading cheers
August 26, 20188 yr @Atti2de - You are running a wine fridge and aircons off your batteries? 1. Wine Fridge! Seriously? 2.Aircons: Are you trying to purposely stress your batteries? I am hoping that the post was supposed to be humorous. Are you completely off-grid? If not, why are you stressing your Pylontechs with your Aircons, and so deeply discharged? I understand that they can last through such huge and multiple cycles, but at the price you paid there is no way you are going to recover your cost if you push them that hard?
August 26, 20188 yr Author @KLEVA, what I was saying is that the inverter is feeding back into the grid to turn the meter back when it detects usage on the “grid only” circuit. I set the export limit to 0W now, let’s see if it doesn’t try to push the energy back for stuff it shouldn’t. I wasn’t expecting it to do it, nor trying to trash the batteries. I followed the instructions carefully and installed the EZ meter as directed.
September 10, 20187 yr Author YAY! Did everyone have a great generation day yesterday? Made 18kWh!!!! Love this!
September 10, 20187 yr 2 hours ago, Atti2de said: Did everyone have a great generation day yesterday? Made 18kWh!!!! Yes, yesterday was great, gave extra load as a test yesterday and ended on 26KWh...
November 19, 20187 yr Author Morning all! Hope you had a great day yesterday. Must say that this is truly awesome. I have learnt quite a bit from you guys! Thank you especially to @Chris Hobson and @KLEVA. So, thus far I have basically been pushing back into the grid daily and only use the batteries when/ if required. The meter seems to have run backward.... Anyhow, awesome day of producing yesterday! You will see that in the late afternoon I decided to switch on the aircon (which is connected to the grid). It seems the best way to do this is to use your system as a grid tie solution, with battery as backup. (In my case at least)
November 22, 20187 yr Hi @Atti2de, thanks for all the great posts. I'l be installing a really similar setup to you in the near future and was also puzzling over 2 strings x 5 panels each OR 1 string x 10 panels (in my scenario). So this post has been really helpful in that regard. Perhaps I missed the post but have you stuck with your 1 x 12 setup or reverted back to the 2 x 6?
November 23, 20187 yr Author Hey @Super_mil, Thank you for the comments! I am stuck with the 1 large series string! The higher voltage seems to favor the MPPT chargers...
