October 6, 20232 yr Hello does anyone know how to enable email notifications in ICC. I have tried several times but i cant seem to get it right. The support from the distributor of ICC is not very helpful.
October 6, 20232 yr Perhaps try adding your email address in both the From and to field then test. Also try using the TLS port instead of SSL port 587
October 9, 20232 yr Have you made certain to allow access to your gmail account to send email ? You need to create an App password under security... or something like that.
October 9, 20232 yr On 2023/10/06 at 3:45 PM, CM21 said: Hello does anyone know how to enable email notifications in ICC. I have tried several times but i cant seem to get it right. The support from the distributor of ICC is not very helpful. Are you using a custom "app password" or just your Gmail password you sign in with? If the app (ie ICC) doesn't support "Modern Authentication" then your normal password won't work as mentioned above
November 19, 20232 yr Author On 2023/10/09 at 11:02 AM, PsyWulf said: Are you using a custom "app password" or just your Gmail password you sign in with? If the app (ie ICC) doesn't support "Modern Authentication" then your normal password won't work as mentioned above My Gmail password is the same on both the app version and the web version of mail.
November 20, 20232 yr 7 hours ago, CM21 said: My Gmail password is the same on both the app version and the web version of mail. That's not what he's saying.
November 20, 20232 yr 13 hours ago, CM21 said: My Gmail password is the same on both the app version and the web version of mail. No. https://support.google.com/mail/answer/185833?hl=en
