March 2, 20224 yr Also, the US2000B plus has a RJ11 console port as well as a RJ45 CAN and RJ45 RS485, which one to use? Edited March 2, 20224 yr by Speedster Add screenshot
March 2, 20224 yr On 2021/12/30 at 8:36 AM, Don B. Cilly said: Greetings from Ibiza, Spain. I'd like to ask, I type sudo screen /dev/ttyXRUSB0 1200 and I do get a screen. Blank. I can't paste anything in there. If I use 115200, I get a screen full of scrolling gibberish and no prompt. Any suggestions? Were you able to solve this? I get the same error blank, unresponsive screen.
March 3, 20224 yr On 2021/07/12 at 10:01 PM, Gavin Coutts Energy Max said: To connect to pylontech batteries You need a RS232 to usb converter which is normally purchased. From the RS 232 you connect to RJ12 with pinouts as above. Open a terminal port in your Mac OS or windows make sure you are Sudo Download a app called screen.. install connect the RS 232 to the console port with the battery switched on first, then to the USB port of your laptop. Check through hardware systems check the USB port address.. eg A10K282M The Pylontech defaults to baud rate 1200 to start. Type in the following command in your terminal command line sudo screen /dev/tty.usbserial-A10K282M 1200 Paste the following instruction too initiate comms ~20014682C0048520FCC3 Push enter Hold ctrl+a then type k then type y [to exit] Type in following command sudo screen /dev/tty.usbserial-A10K282M 115200 This is the baud rate for comms to console commands 115 200 Press enter twice You will then have the prompt pylon> Under this prompt you have the following options displayed after typing in help pylon>help @ Local command: bat Battery data show - bat [pwr][index] data History data load - data [event/history/misc][item] datalist Show recorded data - datalist [event/history/misc][item/bat][batnun][volt/curr/temp/coul][item] disp Display Info at regular intervals - disp [(pwrs pwrNo)/val]/[(bats batNo)/volt/curr/temp] getpwr Get power Info - getpwr help Help [cmd] info Device infomation - info log Log information show - log login Login Admin mode - login [password] logout user mode - logout pwr Power data show - pwr [index] shut Shut down - shut soh State of health - soh [addr] stat Statistic data show - stat time Time - time [year] [month] [day] [hour] [minute] [second] trst Test Soft Reset - trst updata updata system - updata ********************************************************** Remote command: Press [Enter] to be continued,other key to exit Best results for all problems and configs is to type login debug with this command you ahem the following options pylon_debug>help @ Local command: adc Addr show - adc bat Battery data show - bat [pwr][index] bmicbld BMIC Soft Bleed Ctrl - bmicbld [chip][Val] bmicd BMIC data show - bmicd [chip] bmice Setup BMIC - bmice [chip] bmicr BMIC read - bmicr [chip][Offset] bmicsh BMIC show reg -bmicsh [chip] bmicw BMIC write - bmicw [chip][Offset][Val] chgver Change soft Version - chgver [st/ph] ci Current Comm Info config config [pov/povr/phv/phvr/plv/plvr/puv/puvr/pslp/bov/bovr/bhv/bhvr/blv/blvr/buv/buvr/bslp/bsv/bv /cot/cotr/cht/chtr/clt/cltr/cut/cutr/dot/dotr/dht/dhtr/dlt/dltr/dut/dutr/coc/coca/cocar /eot/eotr/eht/ehtr/elt/eltr/eut/eutr/doc/doca/docar/ocd/ocr/sc/scd/scr/clc /recinv/shuttime/uvtime/save/default][val] /[sleep/record][on/off/day/week/month][starttime][endtime] /[hwsleep][<on/off>][sleeptime][wakeuptime] ct Track Comm Port Data [Port Number] ctrl Contrl IO - ctrl [cfet/dfet/buzz/heat] [on/off] data History data load - data [event/history/misc][item] datac Clear data - datac [event/history/misc] datalist Show recorded data - datalist [event/history/misc][item/bat][batnun][volt/curr/temp/coul][item] disp Display Info at regular intervals - disp [(pwrs pwrNo)/val]/[(bats batNo)/volt/curr/temp] eepe EEPROM erase - eepe [chip] eepr EEPROM read - eepr [chip][Offset][size] eepw EEPROM write - eepw [chip][Offset][Val][size] flae Extend flash erase - flae [chip] flar Extend flash read - flar [chip][Offset][size] flaw Extend flash write - flaw [chip][Offset][Val] fullchg Show FullCharge Info - fullchg [time] getpwr Get power Info - getpwr help Help [cmd] info Device infomation - info log Log information show - log login Login Admin mode - login [password] logc Log clear - logc Press [Enter] to be continued,other key to exit logout user mode - logout logt Log test - logt [data] md Memory dump - md [width][Addr][size] mm Memory set - mm [width][Addr][Val] m2s Master updata to Slave - m2s prot Protect ctrl - prot [bov/bhv/blv/buv/pov/phv/plv/puv/cbot/cbht/cblt/cbut/dbot/dbht/dblt/dbut/pot/pht/plt/put/coc/coc2/coca/doc/doc2/doca/sc/buzz/smartchg/default][en/dis] pwr Power data show - pwr [index] re Send Command To the Specified Power - re [addr][command] rtcr RTC read - rtcr [Offset] rtcw RTC write - rtcw [Offset][Val] rtcsh RTC show reg -rtcsh save Save data - save [event/history] socr SOC read - socr[Offset] socw SOC write - socw [Offset][Val] socsh SOC show reg -socsh soccfg SOC config - soccfg[subclass][Offset][value] soccal SOC calibration - soccal [volt/current/tempr/ccoffset/bdoffset] [value] socd SOC show data - socd ********************************************************** Remote command: Command completed successfully $$ Thanks for this! Could you help to let me know which is the cycle count? Device address 1 Data Items : 1919 HisData Items : 2041 MiscData Items : 130 Charge Cnt. : 0 Discharge Cnt. : 0 Charge Times : 39890 Status Cnt. : 1051 Idle Times : 27914 COC Times : 0 DOC Times : 0 COCA Times : 2 DOCA Times : 0 SC Times : 0 Bat OV Times : 31 Bat HV Times : 85 Bat LV Times : 0 Bat UV Times : 0 Bat SLP Times : 0 Pwr OV Times : 828 Pwr HV Times : 1377 Pwr LV Times : 0 Pwr UV Times : 0 Pwr SLP Times : 0 COT Times : 0 CUT Times : 0 DOT Times : 0 DUT Times : 0 CHT Times : 0 CLT Times : 0 DHT Times : 0 DLT Times : 0 Shut Times : 21 Reset Times : 112 RV Times : 0 Input OV Times : 1 SOH Times : 0 BMICERR Times : 0 CYCLE Times : 12 Pwr Percent : 97 Pwr Coulomb : 175821580 Dsg Cap : 641371 [email protected] Cnt : 0 [email protected] Cnt : 0 HT Cnt : 0 LT Cnt : 0 LV Cnt : 109 LifeWarn Times : 0 LifeAlarm Times : 0 Command completed successfully Edited March 3, 20224 yr by Speedster
March 3, 20224 yr 1 hour ago, SolarNoob said: @Speedster You can download and use this free software to extract the data from your pylontech batteries http://multisibcontrol.net/ I tried that but couldn't get it to connect, it keeps saying "Pylon stopped" but these terminal commands work. Now it's just about interpreting them correctly. Edited March 3, 20224 yr by Speedster
March 3, 20224 yr 5 minutes ago, SolarNoob said: Did you configure the correct COM port in the software? You need to look under device manager and use the same COM port that Windows picks up. Yes, I did. And tried two different cables. No joy on that front as yet
March 6, 20224 yr On 2022/03/02 at 6:26 PM, Speedster said: Were you able to solve this? I get the same error blank, unresponsive screen. No, but it looks like you did. How?
March 6, 20224 yr 1 minute ago, Don B. Cilly said: No, but it looks like you did. How? I had initially had the TXD and RXD cables the wrong way around. When I swopped them around it worked. I used terminal on my Mac and after issuing the first command (sudo screen /dev/tty.xxx 1200) it gives what seems to be a blank terminal. Pasting the communication code ~20014682C0048520FCC3 looks like nothing has happened, but it has. You might even return a ? character when attempting to paste/type something again. Hold ctrl-a and press "k" to exit the screen session. Then you simply issue sudo screen /dev/tty.xxx 115200, hit return and you should get the pylon> prompt.
August 15, 20223 yr Is there a reason here everyone is recommending different software. I contacted Pylontech a couple months ago when I noticed my batteries wouldn't charge above 88% SOC, and they sent me some software called BatteryView. Why isn't anyone in this discussion using that program? Anyway, just thought I'd chime in, because I've been dealing with this battery problem now for two months, and one of the batteries has finally triggered an "internal failure" alarm. These batteries are only 1 year old. They are the US3000 batteries. The rest of the stack seems out of balance too, but that's a different topic for a different thread. My present concern is that I can't get the BatteryView software to connect. When I click "connect" it says it's connecting for a minute or so, and then gives me a timeout prompt. Well I got the only RS232-RJ11 cable available on the internet in this country, so needless to say, I won't be trying this with a different cable. I don't understand why Pylontech doesn't offer their own diagnostic cables for sale, so we don't have to guess what the problem is. I just hope that the distributor is worth their salt and either gives me some replacement batteries or preferably just gives me my money back. These batteries, with their glitches after only one year, are definitely not worth the 2000USD they cost in this country.
December 20, 20223 yr On 2021/07/12 at 11:01 PM, Gavin Coutts Energy Max said: To connect to pylontech batteries You need a RS232 to usb converter which is normally purchased. From the RS 232 you connect to RJ12 with pinouts as above. Open a terminal port in your Mac OS or windows make sure you are Sudo Download a app called screen.. install connect the RS 232 to the console port with the battery switched on first, then to the USB port of your laptop. Check through hardware systems check the USB port address.. eg A10K282M The Pylontech defaults to baud rate 1200 to start. Type in the following command in your terminal command line sudo screen /dev/tty.usbserial-A10K282M 1200 Paste the following instruction too initiate comms ~20014682C0048520FCC3 Push enter Hold ctrl+a then type k then type y [to exit] Type in following command sudo screen /dev/tty.usbserial-A10K282M 115200 This is the baud rate for comms to console commands 115 200 Press enter twice You will then have the prompt pylon> Under this prompt you have the following options displayed after typing in help pylon>help @ Local command: bat Battery data show - bat [pwr][index] data History data load - data [event/history/misc][item] datalist Show recorded data - datalist [event/history/misc][item/bat][batnun][volt/curr/temp/coul][item] disp Display Info at regular intervals - disp [(pwrs pwrNo)/val]/[(bats batNo)/volt/curr/temp] getpwr Get power Info - getpwr help Help [cmd] info Device infomation - info log Log information show - log login Login Admin mode - login [password] logout user mode - logout pwr Power data show - pwr [index] shut Shut down - shut soh State of health - soh [addr] stat Statistic data show - stat time Time - time [year] [month] [day] [hour] [minute] [second] trst Test Soft Reset - trst updata updata system - updata ********************************************************** Remote command: Press [Enter] to be continued,other key to exit Best results for all problems and configs is to type login debug with this command you ahem the following options pylon_debug>help @ Local command: adc Addr show - adc bat Battery data show - bat [pwr][index] bmicbld BMIC Soft Bleed Ctrl - bmicbld [chip][Val] bmicd BMIC data show - bmicd [chip] bmice Setup BMIC - bmice [chip] bmicr BMIC read - bmicr [chip][Offset] bmicsh BMIC show reg -bmicsh [chip] bmicw BMIC write - bmicw [chip][Offset][Val] chgver Change soft Version - chgver [st/ph] ci Current Comm Info config config [pov/povr/phv/phvr/plv/plvr/puv/puvr/pslp/bov/bovr/bhv/bhvr/blv/blvr/buv/buvr/bslp/bsv/bv /cot/cotr/cht/chtr/clt/cltr/cut/cutr/dot/dotr/dht/dhtr/dlt/dltr/dut/dutr/coc/coca/cocar /eot/eotr/eht/ehtr/elt/eltr/eut/eutr/doc/doca/docar/ocd/ocr/sc/scd/scr/clc /recinv/shuttime/uvtime/save/default][val] /[sleep/record][on/off/day/week/month][starttime][endtime] /[hwsleep][<on/off>][sleeptime][wakeuptime] ct Track Comm Port Data [Port Number] ctrl Contrl IO - ctrl [cfet/dfet/buzz/heat] [on/off] data History data load - data [event/history/misc][item] datac Clear data - datac [event/history/misc] datalist Show recorded data - datalist [event/history/misc][item/bat][batnun][volt/curr/temp/coul][item] disp Display Info at regular intervals - disp [(pwrs pwrNo)/val]/[(bats batNo)/volt/curr/temp] eepe EEPROM erase - eepe [chip] eepr EEPROM read - eepr [chip][Offset][size] eepw EEPROM write - eepw [chip][Offset][Val][size] flae Extend flash erase - flae [chip] flar Extend flash read - flar [chip][Offset][size] flaw Extend flash write - flaw [chip][Offset][Val] fullchg Show FullCharge Info - fullchg [time] getpwr Get power Info - getpwr help Help [cmd] info Device infomation - info log Log information show - log login Login Admin mode - login [password] logc Log clear - logc Press [Enter] to be continued,other key to exit logout user mode - logout logt Log test - logt [data] md Memory dump - md [width][Addr][size] mm Memory set - mm [width][Addr][Val] m2s Master updata to Slave - m2s prot Protect ctrl - prot [bov/bhv/blv/buv/pov/phv/plv/puv/cbot/cbht/cblt/cbut/dbot/dbht/dblt/dbut/pot/pht/plt/put/coc/coc2/coca/doc/doc2/doca/sc/buzz/smartchg/default][en/dis] pwr Power data show - pwr [index] re Send Command To the Specified Power - re [addr][command] rtcr RTC read - rtcr [Offset] rtcw RTC write - rtcw [Offset][Val] rtcsh RTC show reg -rtcsh save Save data - save [event/history] socr SOC read - socr[Offset] socw SOC write - socw [Offset][Val] socsh SOC show reg -socsh soccfg SOC config - soccfg[subclass][Offset][value] soccal SOC calibration - soccal [volt/current/tempr/ccoffset/bdoffset] [value] socd SOC show data - socd ********************************************************** Remote command: Command completed successfully $$ Hi, can I change the max possible charge current given by BMS if I have 2 batteries connected in parallel? My inverter has a firmware bug and cannot charge both batteries if they are ready to accept 2x0.5C. Or is it better to connect Arduino between the BMS CAN bus and my inverter to override the value if needed?
February 8, 20233 yr Hi, I have a stack of Pylontech Force L2 batteries. Has anyone tried or does anyone know if the RS232 port on the rear of the BMS would work with Multisibcontrol software? Many thanks....
September 14, 20232 yr I wanted to check in on my battery cycles but after I got this to work nicely a couple of years ago, I can't seem to connect again. Is there any easy way to get this done?
September 18, 20232 yr ... not knowing enough... but with the can bus/RS485 port. Can we not repurpose Kellerza's esp32 esphome code? Thinking if the Pylontec's expose a RS485 port, then hopefully we can modbus prob the values ? which mean we can push then as sensors onto HA as #1 option. The other option is to do the probing via Python (running on RPi Zero) and package values into JSON and mqtt publish it. G
July 12, 20242 yr Hello, for those interested, for update us5000 firmware new chip. I tried the .zip but batteryview gave me an error code and systematically closed. This version is V1.7 from January 2024 Firmware-US5000-V1.7ST1.4_2024-01-12-152157_hofs then take the .zip but not having worked I only took the US_E3_V1.7_Crc.bin so it could not be used the US5000_V1.4_Crc.bin the firmware US_E3_V1.7_Crc.bin has passed and the version is V1.7 Now is my shift done correctly I don't know but it works. If anyone wants to give us feedback on the.zip to see if they can pass it to find out le firmware a été pris ici : https://www.zcsazzurro.com/fr/documentation/pylontec-box Only the bottom Battery had fewer lights indicating the percentage of charge than before (as if the 3 batteries were not one because the percentage of charge must be similar in this case) then 1 hour later everything was back to the same before therefore a percentage identical to the others. Before restarting the batteries, the inverter had a voltage alarm fault and the inverter electrical inlet circuit as well as its indicator light were cut off. Then after about 5 to 10 minutes without doing anything or almost "I just changed the battery first in the parameter" everything came back to normal. If you have an idea. otherwise, I had to change the PC because it did not want to connect, telling me that the com port was already occupied and even changing the physical port or modifying it by hand in advanced com port settings and restarting Windows: Same ? Hi. Firmware-US5000-V1.7ST1.4_2024-01-12-152157_hofs.rar
July 12, 20242 yr 2 minutes ago, chris50 said: Hello, for those interested, for update us5000 firmware new chip. I tried the .zip but batteryview gave me an error code and systematically closed. This version is V1.7 from January 2024 Firmware-US5000-V1.7ST1.4_2024-01-12-152157_hofs then take the .zip but not having worked I only took the US_E3_V1.7_Crc.bin so it could not be used the US5000_V1.4_Crc.bin the firmware US_E3_V1.7_Crc.bin has passed and the version is V1.7 Now is my shift done correctly I don't know but it works. If anyone wants to give us feedback on the.zip to see if they can pass it to find out le firmware a été pris ici : https://www.zcsazzurro.com/fr/documentation/pylontec-box Only the bottom Battery had fewer lights indicating the percentage of charge than before (as if the 3 batteries were not one because the percentage of charge must be similar in this case) then 1 hour later everything was back to the same before therefore a percentage identical to the others. Before restarting the batteries, the inverter had a voltage alarm fault and the inverter electrical inlet circuit as well as its indicator light were cut off. Then after about 5 to 10 minutes without doing anything or almost "I just changed the battery first in the parameter" everything came back to normal. If you have an idea. otherwise, I had to change the PC because it did not want to connect, telling me that the com port was already occupied and even changing the physical port or modifying it by hand in advanced com port settings and restarting Windows: Same ? Also to respond to the RS485 connection problem I had the case where in solar assistant I had modified the CAN port to RS485 and I searched for 2 days to find it on a DEYE, finally I reconnected in RS232/usb on the inverter via the raspberry where solar assistant is installed and by resetting CAN0, I managed to regain control. so I am in RS485 on the BMS RS485 port with CAN validated and it works which is curious so be careful with each modification to check carefully after a reboot that everything works again because we quickly forget especially since the problem was declared 2 days later an rpi reboot. Hi. Micrologiciel-US5000-V1.7ST1.4_2024-01-12-152157_hofs.rar
