February 16, 20242 yr Yes, probably better to connect to the Gen port if possible though. There is a box to select for if you are connecting a generator to the grid port. Not 100% sure what it does exactly but I would assume it opens up the permitted frequencies and voltages and slows down the ramping up of the load on the generator so as not to stall the generator. Open to correction from anyone who actually knows 🙂
February 16, 20242 yr I think the tick box is under either the Aux port settings or the grid settings portion of the menu.
February 16, 20242 yr 10 hours ago, Dirkie said: Can you connect a Generator on to the grid side of n 20kw Deye inverter Yes, I have clients running completely off-grid and the Gen is connected to the Grid input and the AUX/GEN is used to run aircons and other non-essentials. The inverter can still start the Generator via normal inverter logic and charge the battery to the desired level (According to the Time-of-use)
December 22, 20241 yr On 2024/02/16 at 9:10 PM, iiznh said: Yes, I have clients running completely off-grid and the Gen is connected to the Grid input and the AUX/GEN is used to run aircons and other non-essentials. The inverter can still start the Generator via normal inverter logic and charge the battery to the desired level (According to the Time-of-use) Can you explain to me how they did this? And if possible with details?
