March 25, 20242 yr Hi folks, As mentioned in the title, can anyone help me find the service manual for this kind of inverter? I really appreciate any help you can provide.
April 10, 20242 yr Here it is: https://ueeshop.ly200-cdn.com/u_file/UPAZ/UPAZ775/2311/16/file/IVEM30245048.pdf
April 10, 20242 yr All on their south african website too with contact details https://www.felicitysolarsa.co.za/usermanualpage
April 4, 20251 yr Does anyone has the repair manual I have more than 3 they are not coming on at all where should I look please and thanks in advance @Coulomb please if you have any hints please anyone
April 7, 20251 yr On 2025/04/05 at 12:41 AM, joshua said:Does anyone has the repair manual I have more than 3 they are not coming on at all where should I look please and thanks in advance @Coulomb please if you have any hints please anyoneWhile I don’t have a repair manual and I cannot tell you why they don’t turn on I have noticed this phenomenon with a few I have installed. Try powering up using a mains feed or solar. The switch on the inverter seems to be a little “cheap” and sometimes needs to be fiddled with (on/off, on/off) to get the machine on when only powered by battery.
April 7, 20251 yr 12 hours ago, Gandalf said:While I don’t have a repair manual and I cannot tell you why they don’t turn on I have noticed this phenomenon with a few I have installed.Try powering up using a mains feed or solar. The switch on the inverter seems to be a little “cheap” and sometimes needs to be fiddled with (on/off, on/off) to get the machine on when only powered by battery.I remember reading some where if the devices on parallel and locked for an error it wont turn on without feeding from the grid on the there input
April 7, 20251 yr On 2025/04/05 at 1:41 AM, joshua said:Does anyone has the repair manual I have more than 3 they are not coming on at all where should I look please and thanks in advance @Coulomb please if you have any hints please anyoneThere are videos on youtube explain Felicity 3kw and 5kw sps and power supply but in arabic voice over1. https://www.youtube.com/watch?v=mMor7kUHjLU 2. https://www.youtube.com/watch?v=WPFRhvhdg3M
April 8, 20251 yr On 2024/04/10 at 10:38 PM, Mika said:Here it is:That's a user manual, not a service manual.As for why a totally new inverter won't come on, that's different. I note that the Axpert circuit that they probably copied has a capacitor that needs to be charged before the start circuit will work, so if it doesn't charge when switched on, wait a few seconds with the switch off before trying again.It may be possible to bridge the power switch (really a load switch, at least on Axperts) contacts with a screwdriver. Be aware that one side of the switch is probably basically unfused battery positive, so don't short the contacts to anything else. That may help to rule in or out poor switch contacts. Edited April 8, 20251 yr by Coulomb
