Axpert 5kVA Error 51
Hi gents
I have bought a second hand Apert 5kVA to use as a single phase emergency charger for my 3 Phase Sunsynk system.
I have no output connected on the Axpert and no Solar Panels.
If I configure the Utility Charge Amps any more than 30A, the unit runs for a few minutes and then result in Error 51, a pain because it isn't self resetting.
I read a bunch of old posts with varying answers from blown caps and components to overheating and earth issues. The fact that it runs longer when configured for lower Amps makes me think overheating, any ideas?
23 hours ago, Beat said:
Does the fan run, are the heatsinks clean?
Hi Beat
Yes, both fans run and the heatsinks look clean. I'll try adding another fan to see if that makes a difference.
On 2024/04/08 at 6:10 AM, AJBotha said:
Hi gents
It might be a hardware problem. I have fixed quite a few inverters in my time but is am not an expert in this field by all means. Maybe @Coulomb or @BritishRacingGreen can comment what the problem could be. It may be the controll card it may be the 400v side of the dc-dc bridge capacitor C73 or C74 if i remember correctly. I know error 51 if persist can end up with a load bang. I would get someone skilled to have a look at it before more damage occurs. The likes of @Vissie or @BritishRacingGreen comes to mind.
