April 3, 20197 yr The are good for grid tied yes, I looked at them a while back, and they are on "the list". But if Eskom goes off, so does the Solis. So you need a solution added to keep stuff powered like a UPS or some such.
April 7, 20197 yr I have used a Solis for over a year now, highly recommend if you wanna save money. Load shedding however is a problem due to the fact that it mist switch of when no grid is available
April 7, 20197 yr The Solis inverters are great inverters and come with 10 year warranty. There are some hybrid models with battery backup as well.
August 23, 20224 yr I have a Solis 4G inverter and are very happy with the unit, however I found zero support for Solis in South Africa. I need some technical information but no one can/ will answer my questions. I couldn't even buy my unit from a dealer or reputable store. The only solution was to buy from an online store that knows nothing technical and thus no support. Solis overseas, India, US and UK refer me back to Solis South Africa who doesn't even respond to my technical info questions. My advice is to stay away from Solis in South Africa as no one will assist with technical issues.
February 3, 20233 yr My experience is different. I have a 6Kw Solis Hybrid inverter and works extremely well. Even a loose connection in a cable were detected and the inverter warned me accordingly. Furthermore, I requested a firmware update and Solis South Africa assisted me promptly contacting me and doing the work remotely. Thank you Solis!
February 4, 20233 yr Hi @Pieter Lourens, are yours also dipping or switching off when loadshedding starts? I have 3 friends with the same inverter and they all report the same. This is irritating me somewhat. I have added a ups for the TV and wifi but still feels I would have liked it more if it didn't. Other than that (as we discussed previously) the inverter is great.
February 4, 20233 yr 5 hours ago, Rolo said: Hi @Pieter Lourens, are yours also dipping or switching off when loadshedding starts? Hi @Rolo, Yes, the dipping as the inverter switch away from the grid tied circuit is normal for all Hybrid inverters. The Solis RHI inverter has a 20 milli second switch over time; switching over is the islanding legislative requirement. I did notice that the later Solis Hybrid (S6) has a 10 milli second change over time. I think the issue is the tolerance of this dipping by the appliances. My TV is the only appliance that shuts when the inverter switches. I hope that helps
February 4, 20233 yr 4 hours ago, flamegrilled said: This is all about a Solis grid tied only that shuts down when the grid is down. I think the question is about the Solis RHI pure hybrid as Pieter has already given details.
February 5, 20233 yr Hi @Scorp007, My first solar set-up was exactly as described in this video and that works well. Essentially that is a hybrid inverter but split into two.
February 5, 20233 yr 1 hour ago, Pieter Lourens said: Hi @Scorp007, My first solar set-up was exactly as described in this video and that works well. Essentially that is a hybrid inverter but split into two. Pieter this is what I have and I worked it out this way and it was interesting at the time to see this video long after I came up with the combination. Also before the video I visited a school friend and what a surprise to see his installer installed the same 2 Inverters. Even if I had a bigger true hybrid I will keep my Solis connected. It just does what it must do in silence. It stays a good way of scaling from 1 system to the next. Edited February 5, 20233 yr by Scorp007
February 7, 20233 yr On 2023/02/03 at 1:48 PM, Pieter Lourens said: Furthermore, I requested a firmware update and Solis South Africa assisted me promptly contacting me and doing the work remotely. Hi @Pieter Lourens, any advantage seen by doing firmware update?
February 8, 20233 yr No, not really. However it did solve my issue in that sometimes the WiFi logger read incorrect Eskom power when switching because of load shedding. I think that because the CT clamp meter is connected to Eskom rather than to my essential load caused this problem. The metering device switches off when Eskom does. PS the CT clamp will remain on Eskom, just the Arcel meter should probably have power all the time. Edited February 8, 20233 yr by Pieter Lourens
February 8, 20233 yr 20 hours ago, Pieter Lourens said: PS the CT clamp will remain on Eskom, just the Arcel meter should probably have power all the time. Hi Pieter, Should probably or should? I have the same config, CT clamp on mains incoming and meter powered before the inverter, so when grid goes down the meter goes down. Also throws my stats out of whack. Did you move the meter to be powered from the essential loads, so on AC Backup output? Edited February 9, 20233 yr by LumexClipsal Spelling
February 9, 20233 yr Hi @LumexClipsal, "Should Probably" because my personal logic says that if the Arcel meter is constantly powered it will not get a misreading. The specification, however, indicates Eskom as the power source. I noticed that when Eskom goes off that I have a misreading but as soon as Eskom is back on, the reading is auto corrected. I believe the firmware upgrade helps with this correction. At some stage I may decide to switch the meters power but that is not a priority now. If you make changes, please let me know how that goes.
March 3, 20233 yr @LumexClipsal, Following from our earlier conversation. I rewired my Arcel meter to be powered from the essential load of my inverter instead; and all seems well. I will let you know should there be any misreading. However, after 5 days I believe all is good
March 3, 20233 yr 29 minutes ago, Pieter Lourens said: @LumexClipsal, Following from our earlier conversation. I rewired my Arcel meter to be powered from the essential load of my inverter instead; and all seems well. I will let you know should there be any misreading. However, after 5 days I believe all is good Thanks Pieter. I think I'll do the same. Is the CT still around the mains incoming at mains DB?
March 3, 20233 yr 1 hour ago, LumexClipsal said: Thanks Pieter. I think I'll do the same. Is the CT still around the mains incoming at mains DB? Hi @LumexClipsal Yes the CT clamp remains as before. Just moved the power source for the meter.
May 15, 20233 yr Good Day All, For technical assistance with Solis Inverters - Please send an e-mail to the below e-mail address sating the following please. 1. Inverter Model 2. Inverter Serial Number 3. Datalogger Serial number 4. Short description of the issue 5. If Possible a short video of the issue Our Technical Support Engineers will respond to your request timeously Please send your enquiry to: [email protected] Thank you
