July 20, 20251 yr 23 minutes ago, WelshDragon80 said:Would the pi be OK in a ip rated box, as I have the pi in a case with fan.. it would run too hot?It should be ok. Mine is inside an enclosure in my garage with ambient temp in summer of 29 and never had any issues with my pi.
July 20, 20251 yr Author Ok thanks very much for ya input and advice.Il grab the bits and make sure it's all water proof and wait for my friend 😅
July 20, 20251 yr Author No roof that's the scaffolding as I only had it installed 2 days ago.. I will be building something like this around it
July 20, 20251 yr 1 hour ago, WelshDragon80 said:Doesn't look like mine doesBummer, that would have made life very easy 😬
July 20, 20251 yr Author 2 hours ago, HennieL said:Bummer, that would have made life very easy 😬It sure would of done 😅 oh well 🥲
July 22, 20251 yr Author Hi managed to set mi rasberry pi up thanks for all the help only issue I'm having now is that I'm using this buck convter in the picture but keep this message"Device experienced 18 voltage dips since boot.Confirm USB power supply is 5V and 3A."So if anyone could tell me what I done wrong be big help Edited July 22, 20251 yr by WelshDragon80
July 22, 20251 yr 21 minutes ago, WelshDragon80 said:Hi managed to set mi rasberry pi up thanks for all the help only issue I'm having now is that I'm using this buck convter in the picture but keep this message"Device experienced 18 voltage dips since boot.Confirm USB power supply is 5V and 3A."So if anyone could tell me what I done wrong be big helpOne of the common problems of these units are if rated at 3A they normally cannot provide it full time. Always better to get a 5A+ if you need 3A.
July 22, 20251 yr Author I read it could be the micro to usb cable I'm using that could be issue... so have to test and see
