September 11, 20251 yr Hi, I'm looking for some help with my solar and battery backup installation in Sandton (Johannesburg). I have a failure on the master battery (red light) and one other is not charging. Can anyone recommend a technical service support team/person/company to come to site and check if the problem is software/hardware/inverter and then recommend a solution. Thank you.
September 11, 20251 yr @Gavin Heron ,It will be useful if you can supply a bit more info on your system, like Inverter & Battery, make and model, as well as how your system is configured, as it may help pinpointing a resource that has come across this scenario before.
September 11, 20251 yr Author 4 minutes ago, Sidewinder said:@Gavin Heron ,It will be useful if you can supply a bit more info on your system, like Inverter & Battery, make and model, as well as how your system is configured, as it may help pinpointing a resource that has come across this scenario before.Thanks @ Sidewinder. 4 x Pylontech batteries (2xUS3000C, 2xUS3000), 8kW Deye inverter (SUN-8K-SG01LP1-EU), 14 x 340W panels. Edited September 11, 20251 yr by Gavin Heron Type
September 18, 2025Sep 18 it seems I have same problem but I am in the WC and am looking for some one to help me fixing my battery.! Edited September 18, 2025Sep 18 by ibiza
October 3, 2025Oct 3 Red light, also happens when the battery is in standby, switch off the battery and restart it
October 3, 2025Oct 3 thanks for your reply Shockin. It didn't work. I took it to Segan Solar for repair and am expecting their finding today.
October 14, 2025Oct 14 On 2025/10/03 at 8:23 AM, ibiza said:thanks for your reply Shockin. It didn't work. I took it to Segan Solar for repair and am expecting their finding today.Hi there. Did you ever get feedback from Segen? They would have downloaded the logs and sent then to China analysis. There is a likely chance that they will reject your claim stating the batteries have been overcharged. "Common problem"
October 18, 2025Oct 18 Hi Wynem, It seems you are right. My battery is steel with them with no answer yet
November 4, 2025Nov 4 I got my battery back and fixed. Nothing was wrong with it. The voltage was low. They recharged it and it is working now. They sent it to the Durban branch for fixing
December 8, 2025Dec 8 On 11/9/2025 at 8:00, Gavin Heron said:Hola, necesito ayuda con la instalación de mi sistema solar y de respaldo de baterías en Sandton (Johannesburgo). Tengo una falla en la batería principal (luz roja) y otra no carga. ¿Alguien podría recomendarme un equipo/persona/empresa de servicio técnico que venga a comprobar si el problema es de software/hardware/inversor y recomendar una solución? Gracias.Hola defecto en las celdas y puentes entre celdas de mal litio q lleva la batería sobre los dos años de uso falla Míralas por detrás. Se deforma el casco ce la batería...fosfato de funda de pastico litio malo
