Running a 3 Phase Pump on Single Phase.
I have a 2.2kw 400 Volt pump 200 m away from my house at the river. I want to change my eskom supply from 3 Phase to single Phase. Will one of these Units work ?
220V/380V 1.5KW/2.2KW VARIABLE FREQUENCY DRIVE VFD INVERTER
Show us pump graphs and then we can have a sensible talk. Pumps are not about horsepower.
Why are you pumping from the river?
Edited by Johandup
i live on a small holding and its my only source of water, the pipe is very old concrete pipes that are joined amd some pieces of 50mm class 6 pvc where it has been replaced. I only really fill a 5000 l water tank and fill water for the animals. it currently runs a 2.2kw pump. head is prop 5 to 6 m from pump to house and from pump to river about 3m. I want to go to single phase and use the same pump on a VSD 1 phase to 3 phase invertor.
You will have a benefit of less friction by replacing the concrete pipe with hope class 6. What is the price on an inverter? I’ve never heard of a 1-3 phase inverter. I am against complicated electronics. Variable speed won’t benefit you as the pump has to rotate at a certain speed to pump water.
With a 10m head over 200m pumping 5000l you can get by with an inexpensive small pump. Plenty for sale on the internet.
Is it not an option for a ram pump too get the water up on the bank and then use a tank and gravity or a smaller pump to move it 200m?Just a thought.I am no expert at this.
Gravity means a bigger diameter pipe and is sloooww.
Unless you can put up a 30m installation and pump to get to 3 bar.
Martin most pumps like that can be converted from 3 phase to single phase with a capacitor.
Have a look at the nameplate on the pump .If you have problems post a photo.
Mmmmh. I've certainly seen this done, but I don't think you can get full power from it. Considering first how a single phase motor works. It needs a slip angle to start the motor (assuming induction motor), so normally how you do it is you have a main winding and an auxiliary winding, and then you put a capacitor on the auxiliary winding to create a small phase shift (and hence a slip angle) so the motor can start properly. Otherwise it will just sit there humming until you spin it by hand.
Now you can do the same thing with a 3-phase motor, just pretend L2 is the auxiliary. It works, but you'll only have about a third of the power.  See here at 5:15.
Also see this one for a rotary converter. Here he uses L3 as an auxiliary windining to get it started, and then he uses the motor as an alternator that makes L2 an L3.
So I'm not saying do this... it's just for interest sake. If it's just one pump, just get a single-phase motor for it.
Yes you will always get a power loss converting from 3 phase to single phase .if you are running the pump below its max capacity (head height) then it might work.
I agree with plonkster I would rather try purchase a single phase pump than convert the old one.
There are lots available on the used market (Facebook) and other places.
It also bothers me a little that my explanation is a bit inaccurate. From what I can see you wire the motor in Delta, put live on L1, neutral on L2, and your capacitor-phase-shifted live on L3. Kinda sorta works but at reduced power.
cable is only 1.5mm over 200 m drawing around 3.4 amps per phase now. its only a 3 core so converting to single phase will be over 10 amps and voltage drop will be to much over that distance. This was like this when i bought the property.
Time to do the sums.
You can also try to buy 2nd hand cable of the right size. There is no need for perfect looking cables - it should be armored anyway.
Why do you want to move away from 3 phase? Unless there is a really compelling reason stay on it.
with eskom i am paying around 2500 availibilty before i use any electricity. if i go single phase this will drop allot. And its my first step towards going unto solar/pv.
