Diy water turbine project
1 hour ago, Shaun0007 said:
Thank you for all the info.. I will set up a basic solar system 2 x 400 watt solar panels a 5kv inverter and 2 x 12v 105 ah and charge controller to have some power on the property.. i will then experiment and play around with the water turbine and hopefully i can get something decent out of it and add it to the existing system.
Just check some of the solar threads for system sizing and getting the right battery sizes.
