October 3, 20196 yr I have tried in so many ways to make emoncms work with the icc but no deal, i am currently running the latest icc version 2.99 but can't for the life of me get it to work. does somebody have a dummy how to for how to go about it?
October 3, 20196 yr I am running 2.88 version from centurion solar, and all is ok. It included Emoncms on the pi, and could be setup to feed both a local and cloud instance of emoncms. If you have a look on the centurion solar and then on the iccsoftware websites one almost gets the impression there was a falling out? If I recall correctly the ICC site talks about advanced reporting only being supported if you buy a specific version of the pi version including the pi and hardware from ICC? And the version numbers of the software are 2.9x, where as the centurion solar ICC software just states there are no further software updates, in the pi version when you check for updates? not sure of this is related to your issue? What problem are you having exactly?
October 3, 20196 yr desiji, ICC already has a fully functional internal emoncms (on the Pi itself), so I presume you mean you need advice with setting up an external emoncms? I am busy building a doc to assist folks with that and I will share it on the site once it's more respectable. If you want to volunteer for guinea pig duties I'll e-mail you an early version... PS: Current versions of ICC will not update to CenturionSolar's site, as Arandoza mentioned above... Edited October 3, 20196 yr by ChristoSnake Additional detail
October 4, 20196 yr Author 12 hours ago, ChristoSnake said: desiji, ICC already has a fully functional internal emoncms (on the Pi itself), so I presume you mean you need advice with setting up an external emoncms? I am busy building a doc to assist folks with that and I will share it on the site once it's more respectable. If you want to volunteer for guinea pig duties I'll e-mail you an early version... PS: Current versions of ICC will not update to CenturionSolar's site, as Arandoza mentioned above... Totally avalaible for volunter duties will really love to be part of that thanks e-mail. [email protected]
October 4, 20196 yr Author 1 hour ago, root said: desiji, you MUST add a node name otherwise it won't work correctly. did but it shows not available on Emoncms website even thou feed input shows input
October 4, 20196 yr Author 2 minutes ago, desiji said: PS: Current versions of ICC will not update to CenturionSolar's site, as Arandoza mentioned above... Now i know why the input is not beeing logged
October 10, 20196 yr Author started with the construction of the Emoncms web, with the help from @Christosnake Doc. first exP.-https://emoncms.org/dashboard/view&id=55138
May 6, 20206 yr On 2019/10/10 at 2:09 PM, desiji said: started with the construction of the Emoncms web, with the help from @Christosnake Doc. first exP.-https://emoncms.org/dashboard/view&id=55138 Awesome dashboard @desiji. Any chance of sharing the feed and dashboard setup? Edited May 6, 20206 yr by svisagie
May 6, 20206 yr 7 minutes ago, desiji said: What do you want to know Firstly, how did you configure your feeds: did you make use of PHPFINA or PHPTIMESERIES and the processing of each of these. A screenshot of you Inputs page in EmonCMS would help a lot. I should actually be able to build my own dashboard based on yours
May 21, 20206 yr On 2019/10/10 at 2:09 PM, desiji said: started with the construction of the Emoncms web, with the help from @Christosnake Doc. first exP.-https://emoncms.org/dashboard/view&id=55138 Wow, nice job! Any change of sharing that .doc?
