March 24, 20206 yr Good day can anyone advice what the normal standby battery discharge should be ? I have a 48v Leoch lithium and getting 12% discharge over night
March 25, 20206 yr Well, first there is the mandatory thing we have to say: Make sure your Leoch is not stolen from a cell phone tower. These batteries were not sold to the public. Second: 12% self-discharge is too much. But that is assuming the 12% is real. SOC is always an estimate. Does it drop another 12% over the next 8 hours or does it level out at some point? Third: Is the battery completely disconnected, or do you have an inverter or something else connected? It is normal to have some discharge from an inverter even if the inverter is in some low-power/no-load/bypass mode, in other words, if you have anything connected to the battery it might not be self-discharge. It might be actual discharge.
March 25, 20206 yr Author Battery was bought legit , battery is wired to a Mercer 5kva discharge is 6pm to 6am 12% idle state
March 25, 20206 yr 19 hours ago, Calvin 101 said: Good day can anyone advice what the normal standby battery discharge should be ? I have a 48v Leoch lithium and getting 12% discharge over night What size battery is this . The 5 kW Mercer use 600 to 700 watts from 6pm to 6am if it is switched on with no load .
March 25, 20206 yr Left Axpert switched on Right Axpert switched off no load . When the Axpert is switched of the discharge is very little . Hope this helps you .
