April 18, 20206 yr I have upgraded my solar setup to a new 5kva inverter and 2 pylontech batteries. I'm selling my my complete previous setup * 3kva axpert Inverter * 4x Trojan T105 re * Victron bmv-700 * Raspberry pi with registered ICC I bought new pi and software so I can sell this setup with the complte record of the battery usage. I have already done my change over. The setup is ready to go I would like to get around R18 500 for the complete setup Please feel free to ask for any further information
April 19, 20206 yr Author What do the experienced members of the forum think of my pricing. I took the total new cost of all items. And this is 60% of the total.
April 20, 20206 yr Author I would consider selling all Items separately if i can pre-line up a buyer for all the Items * 3kva axpert Inverter - R4500 * 4x Trojan T105 re - R9000 * Victron bmv-700 - R2100 * Raspberry pi with registered ICC - R2100 Or R17 500 for All
April 30, 20206 yr Author Would anyone like to make me a offer. Im needing to sell this equipment to buy more solar panels. No one has said my pricing is to expensive, so im assuming the pricing is ok, but im open to a offer
May 1, 20206 yr Hi Charl, How old is this equipment and how many cycles have the batteries done? Regards Doug
May 1, 20206 yr Author The equipment was bought in March 2016 As you can see the average depth of discharge was 35% and the this depth of discharge, you should expect 2250 cycles and i have only used 236 cycles. Even at the deepest discharge you could expect over 1000 cycles
May 5, 20206 yr Thanks Charl, Apologies for the delayed reply. I will pass on this at this point in time, thanks though. Regards Doug
May 5, 20206 yr Hi Charl Does the inverter have a MPPT? Is it loud enough that it will bother you if installed in your living space?
May 5, 20206 yr Author Hi, yes the inverter does have mppt. The fans do make a bit of a noise, but they do not run all the time. So not to bad. The 5kva I have just installed has its fans running almost constant when on load and solar
June 6, 20206 yr Is this still for sale? Interested in the inverter. Edited June 6, 20206 yr by tetrasection
July 14, 20206 yr Hi Charl, if you dont mind - care to message me where you purchased your new system from? i am looking for similar specs to what you have upgraded to. Thanks,
