August 4, 20206 yr 2 x Luxpower inverters 8 x dyness 2.4 KW 3KW wind turbine Off grid with generator backup Needless to say the generator has not run in months 😉 Client can monitor everything remotely using web portal on his phone Installation by Werner from Elecdelite
August 5, 20206 yr Very niiiiiiiiiiice setup 👌 just one issue I see here and it's a major one............. Edit out the blue thingamajig in the picture (it will confuse folks with the other blue smarties) and leave only the very smart looking silver stuff🤣🤣🤣🤣😁🤙
August 5, 20206 yr 3 minutes ago, Gelo said: it will confuse folks with the other blue smarties Wrong shade of blue... looks like JSM power to me... or maybe microcare, not sure
August 5, 20206 yr 15 minutes ago, plonkster said: Wrong shade of blue... looks like JSM power to me... or maybe microcare, not sure 🤣🤣 you know your shades of blue mate👍
August 5, 20206 yr Author The Blue unit is the Wind Turbine Controller with its Dump Load so no V Blue 😉 I know they get confused easily...
June 1, 20242 yr What is needed to add the wind turbine to a luxpower sna 5000 inverter.. I am seriously looking into this to add 600w as to charge the batteries during the night.. Dyness 4.8kw 2 of them. The right advice will be highly appreciated. Morne
August 11, 20242 yr On 2024/06/01 at 2:16 AM, matstix said: What is needed to add the wind turbine to a luxpower sna 5000 inverter.. I am seriously looking into this to add 600w as to charge the batteries during the night.. Dyness 4.8kw 2 of them. The right advice will be highly appreciated. Morne It would be interesting to see what members suggest here.
August 11, 20242 yr @matstix @Scorp007 Before spending a lot of money on a wind turbine you need strong winds to generate any sort of power. First check the Beaufort Wind Scale on google against your location. You need at least Beaufort 5~6 minimum to make any power.
