Dyness Battery BMS PCB
Anyone that can help me with a Dyness B4850 BMS pcb. I need to replace the BMS only.
I dont mind a 2nd hand one.
Please give me a call if you know where I can find one.
Quintin
Module was bought November 2020. We had a lighting strike and that caused the BMS to go. Thank you for your assistance Gelo I will definitely give Andy a call.
21 hours ago, Aspergo said:
Dyness are 15S pouch cells.
Thanks for answering my earlier question Aspergo.
If you look closely at the first photo from QBannister, you will see that there are 16x Mosfets close to the connectors which are connected to the cells for individual cell monitoring. Next to the Mosfets are 16x (pic is a little blurry) SMD resistors for what I assume are the balancing resistors.
Now because there are 17x FETS and 17x balancing resistors leads me to the conclusion that the BMS is also used in a battery with 16S configuration.
The same applies to Shoto. The earlier models of Shoto I believe were 16S but the latest models are similar to the Dyness/Pylontechs/other look-a-likes with a 15S configuration. I can only assume this is for cost saving. A number of other suppliers eg Blue Nova, LBSA have 16S configuration.
  • 2 years later...
  • 1 year later...
On 2025/11/06 at 1:25 PM, gerald5ive said:
Hi, How did you solve this. I have the same issue now. Where can i buy the BMS boards from?
Hi, you can try on ebay for the boards, i have found some of them here in the past.
Best Regards
