Mercer 5KVA
Good day
I am new to this forum can some one please assist I got Meccer 5Kva inverter is there a patch to be able to see it to solar utility then battery only setting is solar battrey and then utility,would appreciate any help Thanks
think only the King and the VM III series have that option, don't tink you can change it, however, Coulomb will hopefully see this post, he is the guru of Axpert inverters
Yes - I believe the setting SUB is what you are looking for (and usually all Axperts have that mode). It will run on solar until your solar production reaches 0 (during which time it will draw the shortfall between load and solar production from the battery). Once your solar productions reaches 0, it will switch over to utility
Maybe you could set your 'Back to Grid Voltage' so high that it will switch over to utility shortly after starting to draw from your batteries
If you do not want to draw from your batteries at all, then you will something like ICC to do time-based switching to utility
That's usually called SOL (SOLar first output source priority).
On 2021/02/15 at 2:52 AM, Cliffie said:
my Merccer only has sbu
I've not heard of an Axpert (most Mecers are Axperts) that only has one Output Source Priority setting option.
What model do you have? There are many 5 kVA models.
What are you using for changing settings? Front panel buttons, Watchpower, ICC, or some other monitoring software?
Hi Coulomb
The settings it has is solar battrey utility or solar or utility that's the 3 settings it has looking to found out if there is away to add a setting solar utility battery so batterys can only be used when load shedding comes,I am using watch power program. Thanks
So your inverter has the following 3 settings, correct?
  1. SBU (Solar, Battery, Utility)
  2. Solar
  3. Utility
In that case, Solar should be what I have been referring to as SUB and Coulomb as SOL
