February 13, 20251 yr 6 minutes ago, Sc00bs said: As far as I am aware, it should be the same registry entry on the 8kw & 16kw. That is correct, How do I incorporate this now?
February 13, 20251 yr 8 minutes ago, kellerza said: Today this sensor only exists in the 3-phase definitions - https://github.com/search?q=repo%3Akellerza%2Fsunsynk shaving&type=code Do you know the register? Try a custom sensor, and feel free to create a PR to add missing ones I have Grid Shaving working on my 16kw using @slipx's ESPHome integration.
February 13, 20251 yr 6 minutes ago, idb said: Will it be able to setup with in @kellerza Sunsynk. Unfortunately I don't us @kellerza's integration myself anymore but it sounds like you could add it as a custom sensor
February 13, 20251 yr 12 minutes ago, Sc00bs said: Unfortunately I don't us @kellerza's integration myself anymore but it sounds like you could add it as a custom sensor Thanks for that. If you abel to guide me in how to add as a custom sensor I will. I am new to these inverter integrations etc.
February 14, 20251 yr 13 hours ago, idb said: Anyone willing to help me with , Would highly be appreciated. KellerZA has a great Github page with the info on how to add an extra sensor there. https://kellerza.github.io/sunsynk/reference/mysensors
February 17, 20251 yr 3 minutes ago, idb said: Thank you very much for the add of the sensor to an update. @kellerza Please let me know which sensors you end up using. I'm not sure if "Peak shaving" or "grid always on" makes any sense https://github.com/kellerza/sunsynk/blob/main/src/sunsynk/definitions/single_phase.py#L246-L251
March 3, 20251 yr Hi, I'm not sure that this is the right place to ask, but here I go:I installed the HA Addon: Sunsynk/Deye Inverter Add-on (multi) with a Waveshare RS485 to Poe ETH (B) adapter connected to my 12k 3phase SunSynk hybrid inverter.The integration works fine, all data is availible both in the dashboard and I can changes parameters and it is updated to the inverter, but I get a lot of timeout issues, the timeout issue is shown in the logs of the add-on as well as in the MQTT sensors - which I presume is coming from the inverter:I have tried many configuration options of the Waveshare device, different ports, tcp and serial-tcp and all results in a number of connection timeouts.The RS485 cable is just 3m long between the Inverter and adapter.Do I need a 120ohm resistor? or maybe a firmware update on the adapter?Have anyone else had the same issues using this same adapter?BRJon BraathenNorway4bb530c7_hass-addon-sunsynk-multi_2025-03-03T18-04-00.767Z.log
