SunSynk - Inverter Monitoring
  • Replies 734
  • Views 208k
On 2023/01/05 at 7:18 PM, shaulf said:
Wow slipx! please can you share your dash with me- it's proper!
That is a very good looking dashboard. Can you kindly share with me aswell please. Thank you
On 2024/02/16 at 4:23 PM, Sc00bs said:
Just use an ESP32, Home Assistant and the YAML code from Slipx06.
You will be able to write settings back to the inverter.
If that is too much for you then just get one of the dongles from Smart Home Integrations, he has one for the 3-phase inverters.
https://smarthomeintegrations.co.za/product/smartdeyedonglev4/
I made a video on setting it up
Assuming this reply was for me - many thanks
I actually got a USB to RS485 board working (ttyUSB0) but I tried to pass it through mbusd which ran fine for a while, but then stopped sending it's data, so I must have an issue with it's config in my docker-compose.yaml file.
Any example of one for mbusd would be greatly appreciated
mbusd is lightweight with no dependencies on external libraries. Docker gives you very little/no benefits in this case.
Trying to run a container built for HASS OS on another platform forces you to understand Docker, mbusd, and the way the HASS OS container was built to load your configuration etc. Which makes things more challenging.
Just run mbusd natively, you will save yourself a lot of effort.
I have a custom Modbus RUT application and am seeing some trouble reading/writing the Deye/Sunsynk. Maybe someone can confirm and help. We are using the modbus port with cable not reading through the logger.
When setting the TOU table, for instance setting all 6 SOC% values to 10%, they change (I can even see on LCD) but after a few seconds are changing some back to original values. Has someone seen this? We are writing the values 1 by 1 and quite slowly.
Also
a) is it possible to read multiple registry values at once? what function code?
b) is it possible to write multiple registry values at once? what function code?
c) what reading speed is recommended so to not get much errors?
Also
I've seen some weird results just reading the date & time from the inverters. It also doesn't match what's shown on the inverter screens. Anyway, your answers:
a) Yes. fc=3; address=from-where-you-start-to-read; quantity=how-many-you-want-to-read
b) Yes. fc=16; address=from-where-you-start-to-write; quantity=how-many-you-want-to-write
c) I query about 30 single registers in a few seconds as part of my own "every 5 second" monitoring via node-red.
Hi all pls i need help.... I read modbus with esp8266 we have more instalation and now i connect inverter and failed crc check with connect can battery... i disconnect can and normal read no error crc .... pls help me with this thak you  bms is seplos
Edited by Josef Slambor
I assume you're using the single port on the inverter for both modbus and CAN?
Are you using a splitter? you may need to rewire the RJ45 connectors to use only the relevant pins, I had a similar issue with my new 5.5kW Sunsynk.
See this page - https://solar-assistant.io/help/deye/2_in_1_bms_port
after I wired each RJ45 to only use the pins needed I got CAN and modbus working normally again...
Edited by RhysMcW
Hi @Ibrahim Azzam
Firstly, I would suggest buying a second hand Intel NUC of Facebook market place instead of a Raspberry Pi.
Works out about the same cost,  you get something that has an SSD drive in it which are way more reliable with Home Assistant that a microsd that the RPi uses and is also a lot faster. Can be found on the marketplace for around R1500.
Secondly, I would then suggest either getting a ESP32/RS485 shield onto which you can either load the code using ESPHome or if you want something that is plug and play just buy the one with Heinz's firmware on it. smarthomeintegrations.co.za  has both options available.
The other option is to use KellerZa's  integration with a USB/RS485 adapter which will probably work out the cheapest. Only down side to this is that you will need to locate your Home Assistant box close to your inveter.
I also have a Youtube Channel with loads of info in regards to the information you are looking for.
4 hours ago, Sc00bs said:
The other option is to use KellerZa's  integration with a USB/RS485 adapter which will probably work out the cheapest. Only down side to this is that you will need to locate your Home Assistant box close to your inverter.
Well not really. The mbusd gateway needs to be close to your inverter but you can run that on a cheap raspberry pi.  I'm using this to monitor a remote (different province) inverter over tailscale.  inverter<-->mbusd(running on raspberry pi with tailscale)<-->HA (kellarZa integration with tailscale)
Do you have an SSD on your Raspberry Pi @slipx  ?
I have heard that the microsd's in the RPi's have very limited life expectancies when used with Home Assistant due to the large number of writes to the database that take place.
my inverter is in the garage and my HA (on a NUC) is in the house with an USB-RS845 adapter and about 18m of cat-5e LAN cable connecting them, working perfectly. The garage and house are connected so the cable just runs up through the ceilings, so no open air and definitely no underground (not that we get much lightning here in CPT). Apparently the distance limit for RS485 is 1200m, so my measly 18m is nothing...
2 hours ago, Zeus-JKR said:
Hi Guys
Which entity do you use for Grid Connected Status on the Sunsynk 8KWA as I cannot find it in my available entities on HA.
binary_sensor.inverter_grid_connected_status
  • 6 months later...
Hi all
Is there maybe someone that can help me.
So I am able to read the data in NODERED. Grid Peak shaving
But I am unable to change the watt value.
Any assistance please.
I assume this is 3ph with these reg numbers?
Can you write other sensors?
Have you considered using something else than nodered, like my HA addon or the ESP32?
With your current hw, it should be a no brained to get my addon working
I can change the value with my using the ESP32 ESPHome integration so it must be somethin in your node red setup.
Not many people, that I know of, that are still using the NodeRed method for inverter queries so you may struggle to find someone able to assist.
Easiest would probably be tro just switch to the Kellerza integration if you can.
  • 5 weeks later...
Hi all
So I have used grid-peak shaving alot with 8kw, this is my first 16kw. Please see the screenshots. I have tested a few different names. Not picking then up.
Any help will be appriciated.
Hi all
Today this sensor only exists in the 3-phase definitions - https://github.com/search?q=repo%3Akellerza%2Fsunsynk shaving&type=code
Do you know the register? Try a custom sensor, and feel free to create a PR to add missing ones
25 minutes ago, idb said:
Hi all
As far as I am aware, it should be the same registry entry on the 8kw & 16kw.
