September 16, 20169 yr 10 minutes ago, Mike said: nope, but i don't rip a new one on the forum. i consider it helping someone out. i make my tom on labour more than components... Respect. Every Tom Dick and their dogs can shop prices, but labour, now that is a skill one pays for with a smile, says I.
September 16, 20169 yr Man, this is totally off-topic, but I just remembered how I totally misjudged a vehicle one day. I stop at the mall next to this Nissan Navarra. Chopped and dropped, low profile shiny wheels. I say to my wife: That car just SHOUTS Kuilsrivier... maybe Mitchells plain. Walk around it to be confronted by a registration plate starting with CFM... NOOOO! :-)
September 16, 20169 yr On 16/09/2016 at 11:03 AM, The Terrible Triplett said: Die 3l Ford sal gestart word ne! 3l Ford, 2l coke en 1l Brandewyn ... dan ry ons lekker en 'ga soek moelikheid me almal' - selfs SWAMBO duck en dive dan. Lyk vir my ons kry mekaar by die Red Lion Hotel in PE. Het soontoe gegaan toe ek in die army was. Altyd sports.
September 21, 20169 yr Author On 16 September 2016 at 9:12 AM, The Terrible Triplett said: So what do you think of the suggestions? Can it work? Need more? Just got back to Joburg, was in Drakensberg for the week. I noticed that nearly all the little rondavels in the farms I drove past had a solar panel. Good to see solar energy is being used where council is not available. I had never seen a PV panel mounted onto a thatch roof rondavel but there is a first time for everything. Back to the drawing board, the more I read the more questions I have! So if a GTI feeds 220v AC power into your homes wiring, what happens if the GTI is generating 500w from PV but the load of the house is 2000w? Will the GTI keep feeding the 500w into the houses wiring and then allow council to add the required 1500w to carry the 2000w load... or will the GTI stop feeding power into your houses wiring and have council supply the 2000w?
September 21, 20169 yr Grid tie sits on the mains sync'd to mains and simply adds to the mains. If less grid fills the gap if making more the surplus backfeeds into the grid. Sent from my SM-G920F using Tapatalk
September 23, 20169 yr Author On 22 September 2016 at 1:45 AM, TinkerBoy said: I have a GTI with battery backup. A GTI will take from grid that PV can not carry. Here where it is yellow the inverter took from the grid where the load was bigger than what the PV could supply. If Grid is - then we are exporting power. Making more than we are using. Thats awesome, thank you! I am on a post paid smart meter, would I be able to feed back into the grid and spin this meter backwards? Or does your inverter have a function which can measure the load and match the PV input to it, that way not feed any power back to the grid? I dont want to get nailed by Eskom and be charged for every kWh I feed back in. I couldnt help but notice the fans for cooling on the inverter, do they run when inverting from DC (PV or Batt) to AC like my Axpert does? I always worry about these fans failing. Maybe I am just paranoid!
September 23, 20169 yr 2 hours ago, Noobie said: I am on a post paid smart meter 33 minutes ago, TinkerBoy said: Before you go GTI make sure your meter can feed back Complex issue this. 1. Old meters, can run backwards. 2. Old meters with reverse lock-up. Won't trip if you run backwards, but won't give you credit either. 3. Prepaid meters that can't see the direction of power flow and bill you for what you push back. 4. Prepaid meters that can detect reverse flow and will trip if you do it. 5. Prepaid meters that can be configured to allow reverse flow (And acount for it, etc, in other words a smart meter, with various levels of smart). If you have a smart meter, you may find it wasn't provisioned to allow reverse flow. The Conlog BEC23 meter so many of us have fits into category 5: It's just smart enough to be a problem :-)
