Solar eclipse 1 Sept 2016
Normally by 10 am there is enough excess energy to power my 1500W 200 litre geyser. If I look at my production I can already see it has reached a plateau at 10 am this morning. Is anyone else experiencing a noticeable effect of the solar eclipse today?
We are cloudy here so will miss the eclipse but I am seeing the same thing if you look at the Southern African group results... huge effect between 11 and 1400.
Sent from my SM-G800F using Tapatalk
Clouds.
2016-09-01 11:20 132.171kWh 1.898kWh/kW 24,871W - - - - 60.197kWh 9,357W
2016-09-01 11:15 132.171kWh 1.898kWh/kW 35,032W - - - - 119.284kWh 15,130W
2016-09-01 11:10 129.282kWh 1.857kWh/kW 34,767W - - - - 117.659kWh 15,269W
2016-09-01 11:05 126.388kWh 1.815kWh/kW 30,433W - - - - 102.597kWh 16,926W
2016-09-01 11:00 123.495kWh 1.773kWh/kW 34,788W - - - - 114.350kWh 19,264W
The Cliff as per the PVO stats ;)
I have updated... PVO depends on uploads by members and the 9 missed some big boys given timing... see my post now... for real time have a look at the link.
I m also not guessing who has clouds or not... so I'm included but this may skew the results.  You can select which sites you want to and so guess who haves sun for example... I guess the impact is best seen by just selecting Northern guys and exclude WC and EC today with the cold front going through ;)
6 minutes ago, Chris Hobson said:
Still dropping with us but not nearly as pronounced. About 85% of 10 am peak.
Went down to about 66% of my regular production now back up to the 85% mark
11 minutes ago, TinkerBoy said:
Amazing to see it has such a big impact. I was outside and can not see a difference with my eyes
The annular path was over Madagascar, Reunion and Tanzania and then over to Central Africa.
Over South Africa the effect was greater in the Transvaal.
