May 26, 20215 yr Hi, I have one of the older Axpert type inverters, 5kVa 4kw. I am looking for a way to monitor the loads etc remotely via the web. What can you recommend? Or do I need to replace the inverter..... If so what is recommended. My PV is stringed in 3's and I do not want to change this. Thanks
May 27, 20215 yr You can buy off the shelve software like ICC or try this great DIY option that I use: HARDWARE: Raspberry Pi 4 (4GB) version USB or serial-USB Cable depending on your interface to the inverter SOFTWARE: Solpilog - polling inverter / power information Telegram - On your cell! Get your inverter stats on the fly! Create a bot. Works great Node-red - Awesome flows! DuckDNS - To link your ever changing WAN IP to a static domain name - Stats / dashboard available as long as you have internet. EmonCMS - Store data. Design your own custom dashboards Docker Let me know and I can build you an image that you can download and try it out!
May 28, 20215 yr Author Thanks this look awesome. How would I interface this with my wifi system to see status on my cellphone when I am not home?
May 29, 20215 yr On 2021/05/28 at 9:52 AM, Namreh said: to see status on my cellphone Use the Telegram app. You would be able to receive automated stats or based on a query i.e. type a command and the bot will return the answer for you.
July 3, 20215 yr @abeetude Do you know if SolPipLog will let you control the inverter as well, e.g. switch mode from SBU to utility or back?
July 3, 20215 yr @SolarFrans I would think yes. You can manually do this by the looks of it, via the timer option or I would guess maybe via mqtt
July 14, 20215 yr Yes, Solpiplog will allow inverter mode switching, as well as charger mode switching too... Definitely.... I am in fact using these features and send the requests via Node Red -> Solpiplog -> Inverter... E
