Achmat Posted June 22, 2021 Share Posted June 22, 2021 (edited) From the latest video from sunsynk, Keith indicates that the 12kw 3 phase inverter is available in SA. I haven't found any pricing online yet so interested to know what the retail price will be. What's also interesting is that the MPPT has been increased to 1 000v and that its 12kw per phase so a total of 36kw. This is a beast of a machine. @Leshenis there a manual with full specs available for this inverter yet and do you know if its available locally yet and retail pricing? https://youtu.be/W1bPeO3fjB0 Edited June 22, 2021 by Achmat Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 1 hour ago, Achmat said: From the latest video from sunsynk, Keith indicates that the 12kw 3 phase inverter is available in SA. I haven't found any pricing online yet so interested to know what the retail price will be. What's also interesting is that the MPPT has been increased to 1 000v and that its 12kw per phase so a total of 36kw. This is a beast of a machine. @Leshenis there a manual with full specs available for this inverter yet and do you know if its available locally yet and retail pricing? https://youtu.be/W1bPeO3fjB0 Hi Achmat. I have the data sheet and manual. See attached data sheet. Three-Phase Hybrid Inverter - Datasheet.pdf Achmat and Yellow Measure 1 1 Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 19 minutes ago, Leshen said: Hi Achmat. I have the data sheet and manual. See attached data sheet. Three-Phase Hybrid Inverter - Datasheet.pdf 2.35 MB · 3 downloads The installation manual is 12mb. I can whatsapp it to u Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 1 hour ago, Achmat said: From the latest video from sunsynk, Keith indicates that the 12kw 3 phase inverter is available in SA. I haven't found any pricing online yet so interested to know what the retail price will be. What's also interesting is that the MPPT has been increased to 1 000v and that its 12kw per phase so a total of 36kw. This is a beast of a machine. @Leshenis there a manual with full specs available for this inverter yet and do you know if its available locally yet and retail pricing? https://youtu.be/W1bPeO3fjB0 Are u sure it’s 12kw per phase? Quote Link to comment Share on other sites More sharing options...
Achmat Posted June 22, 2021 Author Share Posted June 22, 2021 (edited) 8 minutes ago, Leshen said: Are u sure it’s 12kw per phase? The manual doesn't indicate that but if you watch the video, Keith makes it clear that it's 12kw per phase and not using the normal definition where the output is spread across the 3 phases. Really keen to know what they will be going for here as it can run 3 unbalanced phases so you could use it in a single phase off grid house setup and split your loads across 3 phases. 1 phase for geyser, another for plugs and the third for lights, just as an example as the loads do not have to be balanced across the 3 phases. And if Keith is to believes, that's 12kw per phase so it's like having 3 x 12kw single phase inverters. Edit Another example would be 3 separate dwellings on a small holding and feeding each unit from one of the phases. Edited June 22, 2021 by Achmat Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 26 minutes ago, Achmat said: The manual doesn't indicate that but if you watch the video, Keith makes it clear that it's 12kw per phase and not using the normal definition where the output is spread across the 3 phases. Really keen to know what they will be going for here as it can run 3 unbalanced phases so you could use it in a single phase off grid house setup and split your loads across 3 phases. 1 phase for geyser, another for plugs and the third for lights, just as an example as the loads do not have to be balanced across the 3 phases. And if Keith is to believes, that's 12kw per phase so it's like having 3 x 12kw single phase inverters. Edit Another example would be 3 separate dwellings on a small holding and feeding each unit from one of the phases. I think Keith made a mistake. I was told by the engineers that it’s 4kw per phase with a 50% phase imbalance. So it will take 2kw from phase A to phase B which is a max of 6kw. However only time will tell as to what’s true when the inverter is out. Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted June 22, 2021 Share Posted June 22, 2021 Did I hear correctly? 1000V into the MPPTs? Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 3 minutes ago, PaulinNorthcliff said: Did I hear correctly? 1000V into the MPPTs? Yes. Max Voc is 1000V. 15kw total PV. Sunsynk is also developing a 12kw single phase inverter with 15kw PV input. Exciting times. Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted June 22, 2021 Share Posted June 22, 2021 4 minutes ago, Leshen said: Yes. Max Voc is 1000V. 15kw total PV. Sunsynk is also developing a 12kw single phase inverter with 15kw PV input. Exciting times. Get thee behind me, Satan! Leshen and 87 Dream 2 Quote Link to comment Share on other sites More sharing options...
Achmat Posted June 22, 2021 Author Share Posted June 22, 2021 2 minutes ago, Leshen said: Yes. Max Voc is 1000V. 15kw total PV. Sunsynk is also developing a 12kw single phase inverter with 15kw PV input. Exciting times. I'm almost certain the current 8kw was derated by firmware as they were quick to upgrade the mppt to 22A. Would be keen to know the rating of the actual components used as I'm sure they are over spec for the inverter but not keen to open up my inverter to see the components. I'm almost certain it was based off the sol-ark 12k single phase inverter found in the states. Need a tear down of the inverter like Jerry rig everything videos. Quote Link to comment Share on other sites More sharing options...
Leshen Posted June 22, 2021 Share Posted June 22, 2021 2 minutes ago, Achmat said: I'm almost certain the current 8kw was derated by firmware as they were quick to upgrade the mppt to 22A. Would be keen to know the rating of the actual components used as I'm sure they are over spec for the inverter but not keen to open up my inverter to see the components. I'm almost certain it was based off the sol-ark 12k single phase inverter found in the states. Need a tear down of the inverter like Jerry rig everything videos. I was at the Sunsynk repair centre yesterday. Of the many containers that came in of the 8kw unit. There were only 3 that were faulty. These were the original units that came in SA. Quote Link to comment Share on other sites More sharing options...
Bernardf Posted June 23, 2021 Share Posted June 23, 2021 21 hours ago, Achmat said: Need a tear down of the inverter like Jerry rig everything videos. The screen might scratch at a level 6, but it will definitely survive the bend test Yellow Measure and Achmat 1 1 Quote Link to comment Share on other sites More sharing options...
