August 1, 20223 yr Here is the interesting thing... The installer also installed for my brother-in-law, but the Mecer MX2 8K48V witht he same Dyness Battery as mine - works flawlessly. The user interface on that inverter is identical to mine. Edited August 1, 20223 yr by Douw Gerber
August 1, 20223 yr 1 hour ago, Shaunj187za said: Douw pop me a msg on what's app quick 0/7/2/2/14/6/7/1/5 Done
September 2, 20223 yr Hey guys, did you ever get this resolved? I am now having the same issue with the same inverter. I am trying to communicate with a JBD BMS which has rs485 bare cables. I thought it would be as simple as to make a DIY rj45 and connect it up... doesn't work! I have followed the pin assignment from the manual, which is pin 3 is B and pin 5 is A. the battery type is set to 3rd party lithium (LIC). So it should work...but doesn't. I'm pulling my hair out here, any ideas?
September 2, 20223 yr Author For me it was confirmed is a Firmware issue. For now , just set it in USE mode an use voltage.
September 3, 20223 yr On 2022/05/21 at 10:12 PM, Jaxone said: Long story short. I have a Axpert MKS IV 5600 under EaSunPower license... I'll just note for the record (very belatedly) that actually this model is an Axpert VM IV, which looks a lot like an Axpert MKS IV, but an MKS IV has a slightly bigger gap between the bottom of the round display and the top of the cable cover. The proof would be the lack of setting 28; the VM models can't parallel but the MKS models can, and setting 28 (AC output mode) is about paralleling. There is also an Infini (on-grid, capable of exporting) model that looks very much the same and has the same power rating, but it would be am OGrid EASun model instead of an ISolar model. It's all very confusing. I'm also nearly completely convinced that the EASun models that look very genuine (some older models look very different) actually now are legitimately rebranded Voltronic Power models, made in the Voltronic Power factory.
October 6, 20223 yr I also had this issue a while ago with a king that refused to talk to up5000 batts, turned out the battery firmwares needed upgrading and comms started working
April 12, 20233 yr Hello! So the issue was with the battery, not inverter U2 firmware? Because I'm facing the same issue with 61 error on my MKS IV. Edited April 12, 20233 yr by OlehR
April 13, 20233 yr It could also be that you need the capacitor mod. The MKS IVs seem to have this the worst. I note that the OP actually has an Axpert VM IV.
April 13, 20233 yr 8 minutes ago, Coulomb said: It could also be that you need the capacitor mod. The MKS IVs seem to have this the worst. I note that the OP actually has an Axpert VM IV. Thanks, hope that not My inverter is a new one from October 2022, so maybe it's not the case. In some parallel topic was mentioned that U2 firmware update from U2:2212 to U2:2215 fixed that issue.
